3 bar map sensors
Old Oct 15, 2012 | 01:47 PM
Balt_and_Vette's Avatar
3 bar map sensors
Anyone know the proper size for the o-ring on these. I bought them off crate engine again but this time they didn't send me the black ones.
Old Oct 15, 2012 | 02:00 PM
prevsrt4owner's Avatar
Found this: "You need a Viton size 202 o ring. I suggest Mcmaster part 5577K202."
This, too, lol:
Hooked up ds33gt too. I'm down to 40 or so of these things They are milspec buna-n, aka nitrile. I ordered mine from Mcmaster in a 50 count bag, but they were really repackaged from oringsusa. $13 from Mcmaster for a 50 count bag, or 22 cents each plus shipping from oringsusa.
oringsUSA
http://www.mcmaster.com/nav/enter.asp?partnum=5018T239 (price has gone up since I bought them)
I also tried a few Viton and Fluorosilicone, and neither of those options work. Too stiff. You will break the GMS sensor trying to get them on.
Old Oct 15, 2012 | 02:27 PM
Wangspeed's Avatar
This, too, lol:
oringsUSA
Yes, I posted that info some time back.
It appears CED has different orings now, but size 202 is correct. Material is critical. Stick with the buna-n ones from McMaster Carr that I linked.
p.s. Use dielectric grease or some other silicone grease to slip them on. I would pass on engine oil, having had contamination problems with that. Go lightly with the lube!
Old Oct 15, 2012 | 02:30 PM
Black_Mamba_09's Avatar
Not be a dick but im pretty sure CED tells you the map sensors dont come with o rings.
Old Oct 15, 2012 | 02:42 PM
tomj77's Avatar
Meh do what I did when mine tore, left the torn one in and put silicon around it. Holds better than any oring. Just don't drive till its dry.
Old Oct 15, 2012 | 03:01 PM
I've only had my Cobalt SS/TC for a week, and you can tell I'm still a kitten by my join date/post count. Based on observations throughout multiple threads, it looks like Wangspeed knows his stuff.
Old Oct 15, 2012 | 03:36 PM
Wangspeed's Avatar
I think it's best that they do not come with orings. There are 2 sizes. One for HHR, and another for Cobalt. There have been so many mix ups with this. I've fixed multiple cars in this area alone that have had the wrong o-ring.
Bill from GM kindly provided the info that it was -202. It's buried in some thread on here. Sadly, I've not seen anyone from GM post, aside from customer service.
Don't use silicone. That is a phenomenally bad idea. The sensors are extremely sensitive to oil and water, and need to be cleaned off with MAF cleaner once in a while. When? Usually when you start getting BPV flutter.
Thanks prevsrt4owner.
Old Oct 15, 2012 | 04:01 PM
Thanks I have lots of 202's in stock. By the way I'm a industrial parts supplier so I have lots of these types of things in stock haha. Thanks for your help I just didn't want to go home and take the old rings off and then have to bring them in tomorrow for a match-up.
Old Oct 15, 2012 | 04:08 PM
Wangspeed's Avatar
Too bad you live in another country (barely). I do, however, approve of the girls up there.
Old Oct 16, 2012 | 10:41 PM
Maccoy316's Avatar
This sounds like something I need like yesterday! If I'm gonna replace my intercooler I might as well clean my sensors and replace the o-ring, have had the flutter for a while.
Old May 13, 2013 | 01:05 PM
metroplex's Avatar
I probably wouldn't have used Nitrile. I looked at the different O-ring materials and fluorosilicone is probably the best route to go. They all have similar durometer ratings (A70-A75) so one being more "rigid" than the other shouldn't be a problem, just use plenty of lube. The fluorosilicone is also rated to a colder temperature that makes me feel more comfortable. The Buna-N/Nitrile and Viton O-rings don't seem to be rated as low as what the rest of the engine is rated for, but I could be wrong.
I avoided sliding the O-rings over the 3-bar MAP sensors, there is part of the flute that is sharp and could tear into the O-rings if you forced them down. I wrapped the flutes with clear scotch tape so the o-rings would slide right down.
DarrenGC
Dec 24, 2021 01:55 PM
SSLOW06
Oct 1, 2015 07:21 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
