50k miles general maintenance and tune Qs
Old Apr 25, 2014 | 02:59 PM
CrazyVirus's Avatar
Hi all,
I have a 2010 SS/TC full Hahn Racecraft bultons. i just hit 50k and just want to know what general maintenance i should do and and where to get a tune in southern california.
Thank you.
Old Apr 25, 2014 | 03:01 PM
user 72239's Avatar
I have 87k miles on my 08.
What general maintenance are you referring to?
You could replace shocks/struts if you want. Get your valves walnut blasted. change transmission fluid.
Old Apr 30, 2014 | 01:18 AM
RzadkoSS's Avatar
Hello, long time reader but first post.
I was just going to post something similar. I am at 51k miles, just got gms1 put on and waiting for my K&N typhoon intake, then i was thinking about dp/exhaust and a trifecta tune to make it all work well together. I was just wondering if there is any type of preventable maintenance people usually do at 50k to keep it running great. Or if with my mods/ future mods there is anything i should do to maintain reliability? I planned on replacing plugs with ACdelco when i install the intake.
Thanks and i look forward to chatting with everyone finally
Old Apr 30, 2014 | 02:07 AM
Shanedude's Avatar
Coolant/tranny fluid and stock spark plugs @. 75k. Doing same thing @ 150k. Getting real close. Walnut blast valves soon, still get at least 30 mpg might put it off a bit longer.
Old Apr 30, 2014 | 02:17 AM
footballplaya3k's Avatar
First thing I did when I got my LNF was get Powell's air/oil seperator to prevent any further valve coking. Getting your intake valves cleaned is a must. Other than that, plugs for sure. Tranny fluid isn't a bad idea either.
Old Apr 30, 2014 | 04:18 PM
RzadkoSS's Avatar
When should I get my valves cleaned or are there signs to look out for that will tell me they need to be cleaned?
Old Apr 30, 2014 | 04:25 PM
umrdyldo's Avatar
Best thing to do is get a USB camera from ebay and stick it through the brake booster line and view the valves, but I'm guessing they are pretty gross.
Lube the brake slide pins. Change plugs. Change trans fluid.
Old Apr 30, 2014 | 04:26 PM
andrewcarr1993's Avatar
They probably are not very clean now but it can get to the point where you'll have misfires and the engine won't run right or be as powerful. It wouldn't hurt to do it now and get the Powell PVC system so it can't happen again.
Old Apr 30, 2014 | 05:07 PM
user 72239's Avatar
Where is the Brake booster line on the LNF?
Old Apr 30, 2014 | 05:19 PM
umrdyldo's Avatar
https://www.dropbox.com/s/5dud8i0huz...20manifold.jpg
right here
Old Apr 30, 2014 | 07:16 PM
user 72239's Avatar
awesome, thank you very much. Gonna scope mine this weekend
Old May 1, 2014 | 10:20 AM
jaygo7007's Avatar
what type of coolant does tthe lnf take?
Old May 1, 2014 | 10:26 AM
user 72239's Avatar
dexcool.
Old May 1, 2014 | 10:30 AM
dexcool.
Or VW G12 but dexcool is cheaper, learned that from a tdi guru
Old May 1, 2014 | 10:32 AM
jaygo7007's Avatar
prestone dexcool extended life antifreeze/coolant
or
prestone dexcool 50/50 prediluted?
Old May 1, 2014 | 10:34 AM
user 72239's Avatar
I run the prediluted stuff.
bigdeertz
Nov 17, 2016 09:41 AM
deviance
Nov 24, 2015 05:51 PM
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
reybalt
Sep 25, 2015 08:28 PM
