60,000 miles
#53
I wouldn't run what you have in there for a long time but it will be ok for a bit
Only run
88862472 from GM
2 quarts of this
Manual Transmission Fluid SAE 75W-85 GL/4 88862472
or from dealer
Only run
88862472 from GM
2 quarts of this
or from dealer
OP you can run the GL5 stuff for a bit, like till next paycheck assuming your bi-weekly and just got paid last Friday.
#54
60,000 miles
Originally Posted by ECaulk
This. You can take the part number to the dealer and see how much they'll charge you and when it will be available.
#56
60,000 miles
Originally Posted by Shanedude
Nice bud. I'm about to hit 120k miles on my LNF.
By the way does anyone know if the passenger air bag sensor thing is covered by a recall? Mines fucked up like a lot of other people's were. Keep getting the service airbag light.
#58
Nope no huge problems. Haven't paid a cent since warranty ended. Just tires every 40-50,000km, Brake pads and rotors once. Stock suspension is starting to show its age with a bit of rattling in the rear. Hope to take the car to 400,000km but who knows. Oh and I'm Trifecta ECP tuned with a BOV, no coking issues. Still get 28-32mpg. Think ive been pretty lucky. 2010 def the best year.
#59
Honestly not all that bad, did the box end wrench trick on the drain plug with an 8mm Alan key or whatever it's called and used an extension on an 8mm key socket 3/8th drive on the fill plug and it came right off. Tightened the bottom down with just the Alan key and used the 3/8th drive to tighten on the filler plug. Turned out nice, no stripping on the plugs.
Never changed tranny fluid on a car before
#65
60,000 miles
Also just threw a code idk what it is cause I don't have a scanner but engine runs fine no boost leak so I'm assuming it's my catless downpipe I've only had it on for about 1000 miles. I'm getting a tune on Sunday so ill just get that deleted from the ecu.
#67
60,000 miles
Just have him set it to not illuminate.
Any input in the tiny squeaking when I take off? I read on a thread someone said Its the serpentine belt.
#69
60,000 miles
Originally Posted by double clutch
Check the belt for fraying or rub marks. If its bad then get an oem replacement. It could also not be seated on a pulley correctly.
