anyone
anyone
CAn anyone explain why this happens only in first and second YouTube - Clutch slip 2
This was the day before this issue started http://www.youtube.com/watch?v=lKgXU...eature=related
Should slip worse in 3rd, 4th, 5th. 1st and 2nd normally the tires break loose well before the clutch slips. I see mainly speedo lag in those videos not much slip. I should put a video of my car slipping in 3rd from 55-60MPH. RPMs jump to 5200 at 62 MPH then back down to 4300 LOL.
Now that I have seen the video finally (sorry bro laggin on that) Term is right dude... the laggy speedo seems to be the culprit.
The low traction light wouldn't come on if the clutch is slipping... at least it didn't when mine was slipping.
well guess im back to square one again.. looks like traction control is still coming on when it shouldnt be. when vince gets back with me since he is out of town at a funeral i will see what he says about it. i have had issue after issue witth this car for some reason. Vince said form the logs looks like the traction control is always on for some reason. so idk.
Out of random curiosity, what numbers are your tune putting down? I paid the car off months ago, warranty is about to expire (1yr left) and every time I see vids/ride in a tuned one the itch to throw parts/a tune at it gets worse. That looks to be pulling substantially harder than the GMS1 even with the issue
.You know what, random thought and may be completely unrelated. My buddy got dual tuned and his car started acting completely retarded a few weeks after. It would accelerate on its own Toyota style amongst other problems. Further diagnosis showed the ECM was on its way out and needed to be replaced and since then, no issues. If I'm not mistaken TC is handled by the ECM/BCM communicating with one another, but it might be worth a look if Vince said that TC seems to be enabled 100% of the time even when you shut it off to enable the tune?
vince may need slapped sounds like the trifecta tunes are causing some issues lol jk man, mine messes with me to...theres no way ur clutch is slipping that bad all the way to 5 grand lol id say it just needs datalogged and vince will fix it up.
Look like its just lag, i did a video when i got tuned last spring and it look the same...
YouTube - tune trifecta on a cobalt TC
