BADMAB Industries LNF Downpipe is ON!
I'll bite: how do you know?
I can recommend one for anyone that needs it. I've recommended it to a few people on here and, to my knowledge, they haven't had any issues. It comes with a money back guarantee, which is why I chose it in the first place.
I've had that pop a couple times with my ZZP catless. What was weird was it didn't come back after clearing it a few times ...... It's like the car adjusted for it lol. I'm pretty sure Vince turns it off ..... but this happened when i was still on the superchips tune .
The angled O2 extension doesn't allow for enough air to pass over the sensor at cruise, on occasion. As a result, you'll get P013e, unless your tune disables it. If Badmab wants to take the cheaper option, angle the O2 bung slightly towards the turbo housing, and let people use a straight 02 extension. That's not guaranteed to stop either P013e or P0420, but it's a better chance of preventing it.
Honestly, if you care about codes, this is not the right downpipe for you. If you're tuning the car, and want a catless DP, sure, this should be fine, although I don't think anyone has posted pics of the inside of the flex pipe.
Same as every other catless 3" DP. No matter what DP you have if its a catless 3" its gonna do the same. Straight pipe is straight pipe.
I haven't had any complaints about the flex section being too small from any of the guys that have bought them.
And Goldy is right, the dp will give you the same gains any other catless dp would. I do need to get some numbers from someone that has one on though (if anyone on here has run their car on the dyno since installing a BADMAB dp I would be forever greatfull if you e-mailed the numbers over to me
There are quite a few pics at: BAD-MAB.com but if you would like to see more just let me know and I can post some.
Not in the near future. If MA is like NC it should pass inspection as long as your not throwing a code. MA might actually hook up the snorkle instead of just the computer though.
And thank you!
And thank you!
Expensive but if ya need to swap yearly, I would DEFINITLEY look into it.
You buy BOTH the Spun Metal Cat and the straight pipe inserts.
