Belt slip when using NLS
Old Oct 2, 2009 | 07:39 PM
blackvette101's Avatar
Its doing this on my car too.
Old Oct 2, 2009 | 07:44 PM
slowstang's Avatar
My belt slips between shifts. It's not the bypass and it's not the pop from NLS...it's the belt slipping.
Old Oct 2, 2009 | 10:00 PM
DoMiStIc_RuSh_06's Avatar
yup mine did it tonight again as well....seems to be after you do a nls or if you try to shift quick in the lower rpms
Old Oct 2, 2009 | 11:26 PM
Tofu's Avatar
correct. I guess it's pretty normal if everyone is reporting on it, I s'pose I'll stop worrying about it now.
Old Oct 2, 2009 | 11:52 PM
Leveecius's Avatar
Mine kinda sounds like someone starts to sneeze but holds it back! My friends laugh everytime they hear it. I just wrote it off as normal, or I'm not shifting fast enough and the BPV is starting to release.
Old Oct 3, 2009 | 12:00 AM
badbaltguy's Avatar
Originally Posted by Tofu
During an NLS there is a scratch/squeak (the belt slipping) noise that is very noticeable from the engine bay. It happens predominantly on the 1-2 and 2-3 shifts.
yes, when i was stock i noticed the same thing, since then i havent NLS'd much.. but i have always thought it was the clutch grabbing hard and squeaking bad due to high rpms while engaging again... idk though... its a possibility its belt slip though cuz it is pretty loud...
Old Oct 4, 2009 | 04:57 PM
Shibito's Avatar
I finally got this at the track. Didn't run her again after. It was the NLS from 2nd to 3rd. Almost seemed like the car wanted to bog down and die. I heard the squeek and the car took almost a full second to go again. Ran a 13.7 that run and it definitely should have been a 13.0 run or better!!!!!!!
Old Oct 6, 2009 | 02:09 AM
Gyrocon's Avatar
I get the sound. so if indeed it is belt slip, why would performing a NLS cause the belt to slip at all? I don't find the sound results in a less effective NLS BTW. car seems to keep running like a scalded cat
Old Oct 6, 2009 | 02:14 AM
Gimpster's Avatar
Simply put its most likely caused by: Rapid engine deceleration of the engine coupled with inadequate belt tensioning system. On my car shifting fast enough in the right conditions will cause it, not just NLS. NLS is just the sure fire way to hear it typically.
Old Oct 6, 2009 | 02:19 AM
Gyrocon's Avatar
I figured it had to do with inertia of the water pump, alternator ect. wonder if a better belt would solve this problem.
Old Oct 6, 2009 | 10:36 AM
  #36
Terminator2's Avatar
Mine slipped too the other night I hit it in 1st reved to 7400 shifted to 2ndin I heard it squeak a little as I shifted. I never NLS it was a normal shift. It has never done it before that or since.
Old Oct 6, 2009 | 12:31 PM
  #37
MapOfTaziFoSho's Avatar
Mines belts, for sure. I never can hear my stock BPV.
Heard enough belt slips in my life to know hehe.
Nothing like one person's amateur opinion causing a bunch of other amateurs into believing they have belt slip issues...brilliant...
Welcome to the internet kids, the land of experts...
Old Oct 6, 2009 | 12:58 PM
  #38
Tofu's Avatar
Nothing like a self proclaimed professional responding to a thread with no argumentative or supporting evidence of it not being belt slip.
Old Oct 6, 2009 | 01:10 PM
  #39
It was my belt slipping. I have heard that sound enough times to know what it sounds like. What do you think it is Mr. Expert?
Old Oct 6, 2009 | 03:39 PM
  #40
Gimpster's Avatar
Wow, that was an interesting reply.
Short of mounting a mic in my engine bay, not sure how else to prove its the belt like Term just said, and I said earlier.... have heard enough belt slips in my life to know. My F-bodies in particular had VERY similar slips between shifts on hard acceleration. Especially on the LT1 after raising the line pressure. Syclone also has a habit of slipping between shifts as the 700R4 is a very hard shifting transmission.
I'm all ears for other solutions, but don't just attack someone and not offer anything.
Old Oct 6, 2009 | 03:44 PM
  #41
Mine did it right after I hit my 7400 rpm rev limit in 1st gear. It has not done it since and I am at 23-27 psi depending on load with the MBC now.
Old Oct 6, 2009 | 09:13 PM
  #42
steddy2112's Avatar
Look who is back
Anyhoo.
Tuned and NLSing led to this:
And I saw that with my own two eyes.
Old Oct 7, 2009 | 09:21 AM
  #43
Originally Posted by steddy2112
Look who is back
Anyhoo.
What is that piece of mangled metal?
Old Oct 7, 2009 | 10:33 AM
  #44
Idk, I had an f-body with a shift kit...and I know what belt slip sounds like...so that HAS to be it!
Oh, and all GM's have a tendency to belt slip...I know this...
Odds are, it's simply pressure/boost/wastegate/BPV sounds from the turbo...
If you can PROVE it's belt slip, then by all means do so, but coming on here and stating that this is a belt slip issue with the only proof being that 'I've been around a long time'...is crap.
You guys are simply looking for something because you heard a noise.
Old Oct 7, 2009 | 11:30 AM
  #45
09CobaltSS1's Avatar
MapOfTaziFoSho
Old Oct 7, 2009 | 11:37 AM
  #46
HB_SS/TC's Avatar
Pieces of the tranny?
Old Oct 7, 2009 | 12:23 PM
  #47
Originally Posted by 09CobaltSS1
MapOfTaziFoSho
Have anything more useful to add to the discussion?
Old Oct 7, 2009 | 12:32 PM
  #48
CudaJoe's Avatar
Dude everyone knows what a slipping belt sounds like, anyone who can confuse it with anything else probably should not be apart of a car enthusiast forum. Im pretty sure these two guys know if it was a belt slip or not that they were hearing... your making an ass of yourself.
Old Oct 7, 2009 | 12:43 PM
  #49
I thought that exact same thing when reading your bash rant posts.. lol
Figured mine was a little more to the point
Old Oct 7, 2009 | 01:06 PM
  #50
LE5_AJ's Avatar
x2 wtf is that?
