Best Clutch for SS/TC?
I'm sure its been said before, but I'd like to ask again. What is the best clutch for our cars when you still want street drivability and have over 300whp?
Also flywheel?
and do we need the adjustable clutch rod or not?
Also flywheel?
Last edited by jedimastered; 12-07-2009 at 01:34 PM. Reason: addition to question.
Do it once do it right:
http://www.turbotechracing.com/produ...12&idcategory=
You wont regret it. PM us if you find it lower, we will get you the best price.
Again we are not sure on the specific trq rating... It is most likely higher than 350, we are just not sure how much...
With that stated:
No one to my knowledge, who has this exedy hyper single kit, has put enough power down to slip it... It is a very GOOD clutch kit.
With that stated:
Your tires will give up traction before you slip that clutch.
how does it affect the car as a DD? I wouldnt want to have a car that is only good under high throttle. Especially a front wheel drive car. It even says on the web site that the street ability is affected a bit.
I installed thehyper single in my son's SS/SC which is a DD. He was drag racing quite a bit. The Exedy is probably the best clutch manufacturer. The quality is top notch. I believe the clutch was rated at 400 hp. Believe me, you can't abuse this clutch.......it just hooks up and doesn't mind the heat what-so-ever. No other clutch comes close. Just be prepared for a little more pedal effort.
The hyper single will be coming my way in the spring. And I think 06black is running a spec 3+ if I remember correctly when I talked to him while getting tuned
And Ill help ya out with the numbers Aaron. According to Exedy, it handles two times the torque of the stock clutch. Granted that is their generic rating, but that would put it around 500wtq. Also, seeing that it is comparable to stage3+, it should be higher than 350wtq
clutchmasters stage 4 worked good for me. Never slipped. The tranny however happened to fail. Also the clutch pedal was very light. By far the lightest clutch I ever had but the engagement was like an on off switch. No real room to slip it. Everyone who has ever driven my car has stalled it. Even ppl with 30 plus years stick exp. That said though you do get used to it so much so that a stock clutch will feel awkward.
