best mods with gm stage 1 kit?
#103
It's hard to say what the code is from ..... usually it take awhile for LTFT's to change so 5 mins wouldn't do it ....but it could be stft's or maf related . Now that it's on there right.... I would unhook the battery for 5-10 minutes and clear the codes and see if they come back......if they do.... take it a place like autozone and have them check the code for you .
I'll disconnect the batter, but I noticed that I didn't install the filter slightly offset and upside down. It's perfectly upside down so I'll turn it a lil and disconnect the battery.
My friend has an code reader/deleter so I'll have him check it on Monday.
Thanx
#104
You have to disconnect the battery to clear the code. Or, if the condition no longer exists, it will go away on its own after a few off/on cycles. I can't remember how many. It would be better to get the code read, though, then get it cleared by the reader. That way you know what's up.
#105
i just had my IC pipe painted SRTC with metal flake. its sitting on my work bench all purrtty lol
#106
I disconnected the battery, tilted the filter so it was facing 11o'clock. Waited 15 mins and starter it up. No CEL code. Shut car off for 5 minutes. Started up and CEL was there.
Prob need to clean the MAF sensor.
#107
Only other thing I could think of is maybe a piece of dust or dirt got on the maf and it just needs a good spray of cleaner . Good luck !
#110
If I were running GMS1 I would prolly be running a K&N drop in with the ZZP intake tube on the stock Airbox...... The tube off the back of the box is really restrictive with the accordion section and bend . Then maybe take the snorkel off the bottom as well cause it does narrow the inlet down some ....... and a ZZP catless DP .
#116
That's what I did.
Super loud exhausts are only cool for a couple of days. After that, especially if it's your daily driver, the drone becomes insufferable.
I'm gettin a headache just thinking about my old SS with full Vibrant exhaust. Never again.
#117
Im looking at the ZZP LNF downpipe with these options:
Offroad with angled O2 bung - is the offroad the cat? also is angled the one I wanna go with?
both gaskets
additional O2 bung (running an AEM digital Wideband)
Any help is greatly appreciated.
both gaskets
#118
Offroad means NO cat .... the angled o2 will not throw codes for the missing cat. I bought mine with both gaskets but without the extra o2 bung . You only need the extra o2 if you have or bought another wideband for some reason .....most use the factory wideband.
#120
I'd maybe consider going catless if I had a stock catback.. but I bought the car with a fart cannon on it, removed it 2 days later and just did a muffler delete.. so now given my situation, catless is definately a no go.. even the catted DP's are going to be louder than I'd probably originally planned for the car but I'll deal with it
#121
#122
yea.. i wish I had the stock catback, but I sure as hell wasnt going to go out of my way to find an ss/tc muffler when the delete cost me only like $20 to do (w/ OEM tip, piping, and welding included in that price)
#124
a catted downpipe is more expensive than a catless...right?
might save a few bucks by slappin a muffler on now vs. later.. but it might not be that big of a deal
