Big Turbo Stock Motor?
Im wanting to upgrade my stock turbo, I want to know who all is running stock block and internals. If so how much power and boost. I'm planning on doing ZZP stage 2 cams and FMIC. I'm also already Fbo and tuned. I'd like to be 400+ on 93 possibly E85 since we just got it locally
I'm running 257 on 93 and just switching to e47 tonight 100% stock motor right now my suggestion is make a plan for your engine before you go crazy and start ordering parts I'm still on a lnf do I know it will blow some day in future. On 93 I'm guessing 415 give or take 10_15 hp my plan is to beat my motor to death and do full build in future
I'm running stock engine with a zfr and e47 no problems
It's a little more complex than that. On e47 you can make 400+ on any aftermarket turbo that's not tied to the k04. But, depending on the clutch or how hard boost comes in, you may have trans trouble. Plus you also need to make sure you have rotated trans mounts, spherical rear control arm bushings, and good tires or it's all for not. On late 08 early 09 builds, there is potential for the block to get porous. Stock blocks can handle decent power as long as you don't have knock. But if you have a late 08 early 09 built car the block can develop cracks in the cooling passages at any time, even on stock turbo.
You can achieve over 400 without stage 2 cams. There have been plenty of guys running some kind of e fuel making 425-450hp. |
I ran zfr at 28 psi with around 400whp for 2 years all stock motor no issues. if ur going high hp, plan for trans upgrade
What about a zfr 7163 on 93 with stage 2 cams. what power range there.. I want close to 500hp
Not with a trifecta tune.
Not sure if 7163 on 93 will get you to 500whp, but anything over 425whp is pretty crazy in these cars. |
Its not as simple as just throwing parts at it. Dont expect to bolt on a turbo and cams, and be done with it. There are a lot of supporting mods you need for a 450+ whp cobalt to function correctly and be reliable.
I'll agree with ECaulk, probably not going to see 500 with 93 on a 7163, even with cams, and definatley not using Trifecta. I could see low-mid 400's, but you'll need at least some form of E-blend to get close to your goal.
What about a precision 5858 with stage 2 cams and 75# springs with e47 and hptuned??
would you recommend upgrading the pistons to wiseco 86mm and zzp 4340 rods? Or a heavier rod |
have you ever been in a 400 whp or 450 whp FWD car?
why do you want 500 whp? |
With e47 the zfr and cams will take you over 500
Originally Posted by Snail_SS
(Post 7663693)
Yup that the one he mentioned
Originally Posted by ECaulk
(Post 7663694)
with the 7163, not the 6758
yeah only ZZP somehow got a EFR 6758 to over 500 whp :spam:
Originally Posted by double clutch
(Post 7663704)
We will see about that :cool:
(Post 7663709)
Anyone can adjust dynos to make more power. Add nitrous and maybe
he was running 27 psi
So still a little room left. Im not 100% what I am at since we havent finished tuning, but I was at 27 and kmo added more and said he cranked it a bunch.
(Post 7663713)
Colodude is pretty close, and I think he is on stage 1 cams and probably not boosting crazy high, considering he tracks it.
Just pulled up a road log and he was able to hold 27-28 (back calc'd for sea level, so here it was 29-30) all the way to 7500. I'm sure the car wasn't liking the lower load at high rpms, don't have the log of him on the dyno on the computer I have with me.
Stage 3? I thought zzp only made stg 2 lnf cams?
(Post 7663722)
