Boost Guage Malfunction
hey guys just wondering if anyone else's RPD boos guage has given a cancel sign and said data not available. only happens every now and then when i drive really really hard and hit peak boost in like 3rd. usually it goes back, this time it hasnt yet. i turn it off and on and it fixes it but not yet this time. any idea whats goin on?
Yeah usually it will come back after a little while but sometimes it doesn't if you're above ~22.5psi too long.
To fix this disconnect and reconnect either the battery or the ECU itself. This will reset the ECU and it will begin calculating boost again. When somebody connects to your car with Trifecta or HPT it will also fix the gauge.
OK i still have the trifecta cables, so if i plugged in and did like a code search think it would fix it? if i disconnect the ecu will it erase my tune or **** with my warranty?
Disconnecting the ECU will not erase the tune. It didn't when you were stock either. The tune is in memory inside the ECU that is similar to a thumbdrive, that doesn't go away when it doesn't have power. It's actually suggested to reset the ECU after doing mods so the ECU can adjust to them too.
Don't worry, you'll be fine.
this is not always true when i had my car tuned by bcp did hard 1st to second nls and it would come on and the boost guage never came up again from my rpd this happened twice . went to the dealer twice and blew the map sensor. basic fix would be stg 2 map sensor and dont nls anymore
yeah we run 27psi on a gt3076r 09 occasionally the rpd display goes out, but it always comes back. Had another 08 kill his map at the track though on sunday, went to scan via hpt and coming up as 0kpa reading
ur map sensor is blown.i have the same problem right now.dealer said its map sensor
im tuned aslo pushing 21.5.just went out and never came back
Just because a car has a stored fault doesn't mean the sensor is bad. Clear the codes, and try again. Like BYT running a lot of boost and not killed a sensor yet.
A key cycle (also pop open the drivers door) always fixes my RPD when it says NO DATA, but YMMV
I agree with this guy ^ lol
Ive had it show NO code and blank, then reset with my handheld scanner and the RPD suddenly is back to life. Ive also had it where it did throw a code and just needed a reset
That's what I've been saying. Just give the ECU a "e-bump" and it'll usually wake up.
yea im waiting for my code to clear itself lol its been 2 days. i cleared it 3 times on sunday, but no luck yet. ordered the map sensor incase it fails to reset.
In that case (when you're getting codes) I'm leaning away from being able to simply reset it.
yea, when i reset it, it just pops back up so it has to be the sensor thats why i bought it. i did do this thing called a vacuum tank bypass which might have caused it. if so ill be putting the tank back asap!!
