Boost leak check question
If I test for a boost leak, I just take the hotside pipe off where it connects to the turbo and pressurize it from there, right? Do I do anything with the other end that is connected to the TB?
I took the hotside charge piping off and pressurized from there, i didnt go thro the turbo, dont know if that would be a good thing. I even made a little pvc pipe thing with 1/4" inlet to run my compressor into, its neat, there are instructions for similar ones on here. Dont pressurize more than you boost obviously, so make sure you have it regulated.
Cool, thanks. Got any links to those instructions?
Mine is identical to this, I found this after I made mine haha
https://www.cobaltss.net/forums/08-1...ss-lnf-223319/
n20saturn
Sep 30, 2015 12:26 AM
