BOV problem
BOV problem
ok so i relocated my maf to run the bov.... My tuner did my vacuum lines and it runs fine i just lose boost... So i was driving home today and i did a wide open throttle in third and i steadily lost boost from 25 to 20 in seconds... so my question is how do i run my vacuum lines and im running the bpv also...
any help would be appreciated
get a block off plate.
I run both bov and bpv...Have done so for about 20k miles...never had an issue. Been tuned by two different tuners and they've never said anything. I had hahns block off plate and it got a bunch of flutter and crap so I got rid of it.
if you are going to run the block off plate...just take the vacuum line from the bpv and put it on the bov
i had TTR's block off plate and my car hated it, fluttered like hell, i also run the BPV and BOV i just tapped off one of the Vac lines for my BOV and i have my MAF relocated but realized it sucked and my car never ran right so i put it back on my intake and the car runs amazing now
oh ya, my TTR block off plate is now a $40 key chain
OP, Unless you have a turbo swap and can no longer use the Stock BPV, get rid of the new BOV. You don't need it and it's only going to create problems.
the stock BPV will open yes, but the BOV still releases most of the air, i was told running it like that the BPV will be used at parking lots speeds and low boost but anything over that the HKS will take over, and i can hear my HKS pretty much all the time so i dont not believe what he told me
My bov is definately venting
Seems to me like these cars are real finiky about certain things, bov's being one of them. Some people can run both with no problems. Others can't. Some people can run the block off plates...some can't. Kinda sucks.
i know its pointless to run one now but call me ricer i like the way it sounds so that is why im trying to figure the vac lines to run it but if i cant get my **** right i will put the **** right lol
maybe thats ur prob lol shitty BOV, i run the HKS SSQV3
oh ya, also ziptie the ends of your vac lines
Last edited by 07SSYellow; Jul 21, 2011 at 08:49 PM. Reason: Automerged Doublepost
Bo' i can post a pic of my engine bay if you want, but u will have to look to see
here it is
that line coming from the manifold goes to the Lower CP i tapped off that to go to the BOV
i have had ZERO probs with it just so you know also
here it is
Last edited by 07SSYellow; Jul 21, 2011 at 09:08 PM. Reason: Automerged Doublepost
