bpv or bov
Old Feb 10, 2011 | 05:33 AM
jaygo7007's Avatar
bpv or bov
I'm debating on getting a bov, or installing the dejon bpv spring upgrade but I'm torn between the two. Which one would you guys say go for???
I bought a charge pipe like 3 months ago... is there a way I can mod it to run a bov or should I buy the correct one?
I hear some ppl are having issuses with the dejon spring that's why I haven't installed mine yet.
If I was to run a bov would I have to relocated the maf and get retune?
Thanks guys
Old Feb 10, 2011 | 06:13 AM
gotboost?17's Avatar
Nothin Stock
i love my spring sounds so sexy for cheap
Old Feb 10, 2011 | 06:21 AM
jaygo7007's Avatar
Are you having any problems with your spring?????? I guess ima install mine when I get off work. Is there a how to...... I searched but couldn't find anything
Old Feb 10, 2011 | 07:44 AM
CudaJoe's Avatar
Best BPV upgrade money can buy
Old Feb 10, 2011 | 08:13 AM
jaygo7007's Avatar
I want the forge bpv sooooo bad but I hate waiting on the ups guy lol..... plus I already have the dejon spring in hand.
But since that's what's best can you put up a link on where I can order one. I wish modernperformance carried em so I could just drive 5 mins and pick it up lol.
Cudajoe thanks for the pics and nice setup btw
Old Feb 10, 2011 | 08:18 AM
jaygo7007's Avatar
Old Feb 10, 2011 | 08:31 AM
hunter19707's Avatar
Forge Motorsport | Alloy Fabrication
Old Feb 10, 2011 | 09:16 AM
RHZ's Avatar
RHZ
What's wrong with the stock spring? Get the forge or don't even bother IMO.
Old Feb 10, 2011 | 09:24 AM
jaygo7007's Avatar
Stock sucks lol...... nothings wrong with it. I've just been sitting on this spring since forever. Plus I wanna hear the tssssshhhhhh sound
Old Feb 10, 2011 | 09:55 AM
CudaJoe's Avatar
Originally Posted by hunter19707
Thats the correct BPV right there. The Corsa and Astra VXR share the same turbo as us. probably the same motor too.
Old Feb 10, 2011 | 10:49 AM
efactor's Avatar
your gonna end up spending more money if you decide to go to a atmospheric blow off valve. you will need a coldside to relocate the MAF sensor so it will trick the sensor in the back where the turbo manifold is. The sensor in the back will be thinking there is a leak when there is not if you don't relocated the MAF sensor. Plus tuning, and adjusting the BOV to reduce surge and flutter. My best bet if I was you is get the Forge BPV, you don't need an atmospheric BOV for the smaller turbo.
Old Feb 10, 2011 | 12:18 PM
matt638's Avatar
i wanna buy the forge bpv so bad! maybe next month lol
Old Feb 10, 2011 | 12:23 PM
matt638's Avatar
oh, and will the forge bpv work with the stock charge pipe?
Old Feb 10, 2011 | 01:08 PM
Iam Broke's Avatar
Yes.
Old Feb 10, 2011 | 01:24 PM
matt638's Avatar
^thanks man.
Old Feb 11, 2011 | 02:36 AM
Kelu's Avatar
No and No.
Corsa and Astra have different turbos even they might be similar with ours, but hey all BW turbos are almost same including the one from VAG engines (VW, Audi, Skoda, Seat). You are telling something like that all GT28 are same.
None, Corsa and Astra, have LNF, again your are presuming wrong.
Wrong information is worse than no information.
Old Feb 11, 2011 | 08:45 AM
CudaJoe's Avatar
Originally Posted by Kelu
No and No.
Wow, came all the way from eastern Europe to find my post in a forum for a car that doesn't exist in Europe? Congrats information police, you really solved a big mystery here I made an assumption since they are gm vehicles and the forge piece is an exact duplicate of our bpv bolt layout and fitment.
Old Feb 11, 2011 | 12:24 PM
jaygo7007's Avatar
To install the bpv do you disconnect the ic piping or can you leave it on??
Old Feb 11, 2011 | 12:30 PM
cubaniche's Avatar
No. For the Forge BPV the CP can stay in place. Just remove the intake to make life easier. Then its a matter of simply undoing the three bolts of the stock BPV.
Old Feb 11, 2011 | 12:36 PM
I took my stock bpv off yesterday to clean and inspect. I left both intake and cp on, it was kind of a pain. Would be easier to remove intake for more room to work. BTW, what size are the three 10mm bolts and threads, anyone know?
Old Feb 11, 2011 | 12:41 PM
vahdyx's Avatar
I wanna chime in, I currently have the Dejon BPV Spring and the sound is seriously good! I love it, but I only hear it when I go above 5 psi or higher rpms. If I do my daily driving which I shift around 3k rpms, I get surge.
Now I've heard from multiple sources that this low rpm surge is okay! Not a big deal, I keep hearing from other sources that this surge is a bid deal. So since I couldn't decide on what to believe I decided to just buy a forge motorsports spring.
On the positive side, the few Css.net users I PM'd about their spring has all had it on for quite some time. All are tuned and pushing 22psi or more. Those people seem to be having no problems. The people with problems were on stock tune, some not, but most were. So it got me thinking. One person added a downpipe and his problem went away. Not sure how true that is, but he is convinced the back pressure caused surge because the exhaust pressure had no where to go. Opening up the back caused the BPV spring to stay closed and the pressure just went out the back of the turbo instead of slowing it down.
This is all just hear say, just stuff I've read. I can't tell you anything other than, I know I'm getting surge at low rpms and the sound is incredible. I love it. If it wasn't for the surge, I'd love this spring!
P.S. the Forge Motorsports BPV is on back order, they told me they'll have them in around the 16th and can process orders then. I should receive mine on the 23rd of Feb
Old Feb 11, 2011 | 12:46 PM
vahdyx's Avatar
Hey cuda are you getting surge with you Forge with Green spring?
Old Feb 11, 2011 | 01:39 PM
matt638's Avatar
ok so is the forge bpv a good part to get? i love the way it sounds, but i'm not tuned and stock charge pipe for now.... still worth getting?
Old Feb 11, 2011 | 02:15 PM
CudaJoe's Avatar
No , Im not getting any surge. It runs just like the stocker to be honest. Im not tuned either running on the 15Ib spring (green).
Then again im not driving my car hard. I shift at 3000 to 3500rpm. I have gotten on it a few times and noted a that the turbo noise sounded different at full boost when rpms climbed to 5900rpms roughly.
Old Feb 11, 2011 | 02:30 PM
vahdyx's Avatar
Well I'm tuned, should I use the yellow spring?
