Broke the bank and joined the ranks
Edit: WTF how have I not noticed all this **** before? I'm learning all kinds of things about my seats today.
Congrats on the upgrade. Don't get bored with it as fast as I did though. Hell I'm already thinking my Cobra's slow... I need more money for more speed!
Break it in how you're going to drive it.
ok ill break it in as necessary but it's def a milestone for me to pass. i got it monday and now have 325 miles on it cuz all my friends and family want to see it so not too much longer
I knew the seat moved up and down. My G5 had the same feature. However, I never thought about moving it up to help with lumbar support... unless I read the previous posts wrong, which I wouldn't doubt. It's nearing quitting time for me and my brain is already shutting down
Ya, these are the trickiest seats to get comfortable in I've ever had. I found I had to raise the seatpan higher than I normally would (it's all the way up) to get the natural lumbar of the seat in the correct location on my back or it was uncomfortable as ****. Once you have the natural lumbar in the right position, then start workin on the addiitonal setting if required via the knob on the driver's seat (front right under your legs). I guarantee as you move it up, you're going to have to move the seat closer to the pedals and it's going to feel weird for a bit...but now that I'm adjusted, no more back pain
Ya, with these seats you have to throw out everything you typically do with your seat and start from scratch. I found the "wrist test" on the wheel worked well to finally get me setup right. I also had a habit of wanting to rotate my foot from brake to gas instead of lifting it which isn't how the pedal setup in these cars is intended to be used. Once you get things setup the seats are comfortable and supportive for long trips, in the wrong spot (reaching too far, etc) your back is going to hate you
