Burning coolant after turbo swap.
Old Mar 16, 2013 | 06:58 AM
heinen02's Avatar
So last weekend i swapped out the stock turbo with the ZFR, before hand the car perfect, right after first start up white smoke started coming out of the exhaust. i figured maybe some coolant just got in the exhaust so i drove it around a little to see if i couldn't burn it off. After a week of driving its still just as bad as the first day. I lifted the car back up last night and there are no external leaks that i can see and pulled the down pipe off and its completely dry on that side. there was a little oil built up in the coupler that comes off the turbo into the upper charge pipes but the lower charge pipe was dry. the plug tips are a light gray. So far i have had nothing but i giant headache from trying to figure out where the smoke is coming from. just wondering if anyone would have some ideas for me. i have not done compression test or leak down test or anything since i don't have access to that stuff right now.
Old Mar 16, 2013 | 01:49 PM
SSlobalt's Avatar
I don't really know how the turbos hook up, but did you hook up the water cooling to the oil cooling port? Is that even possible? Would that make any difference? Hell, I don't know.
Old Mar 16, 2013 | 01:53 PM
SunburstSS's Avatar
Did you replace the coolant lines gaskets when you swapped in the ZFR ? the only thing I would recommend is reinstalling the coolant lines with new gaskets
Old Mar 16, 2013 | 05:27 PM
Aleksey's Avatar
How are the coolant and oil levels? Did you tune for it?
Old Mar 16, 2013 | 09:12 PM
Nfamous60's Avatar
I was pouring out white smoke it was oil burnin from the turbo, the next thing white smoke could be blow by meaning blow piston ring start u car and remove the oil fill cap see if smoke comes out of there.
Old Mar 17, 2013 | 07:02 PM
heinen02's Avatar
what did you end up doing to fix your problem?
and for the oil and coolant levels, i really havnt noticed and coolant drop and i will have to check the oil again and start keeping track of it. i could be wrong and it could be burning oil. I
Old Mar 17, 2013 | 07:06 PM
Aleksey's Avatar
yeah white smoke wouldn't indicate coolant I don't believe, pretty sure it'd be oil
Old Mar 17, 2013 | 07:32 PM
heinen02's Avatar
do you think i just really need a catch can, or it is something internal in the turbo leaking?
Old Mar 17, 2013 | 07:37 PM
Aleksey's Avatar
Well, first big question is are you tuned for zfr?
Old Mar 17, 2013 | 07:54 PM
heinen02's Avatar
No, not yet. i have tried to MSG James to get tuned, but got no answer so i am prob going to have to go through someone else. I havnt hit full boost yet. Id say i have hit maybe 5 psi on it so far. Im to scared to go any more then that. and my AFR's haven't changed at all since instal.
Old Mar 17, 2013 | 08:15 PM
BLAZIN07SS's Avatar
I'm too JDM for you
white is coolant, blue is oil
Old Mar 18, 2013 | 02:00 AM
Aleksey's Avatar
Yeah hmm since you haven't really boosted much then tuning wouldn't make much of a difference. Any coolant in the oil? In intercooler?
Old Mar 20, 2013 | 10:23 AM
heinen02's Avatar
so i have noticed a slight drop in coolant level, and a large drop in oil level. so im thinking it may be burning both. i did a compression test and got 155, 155, 155, 145.
there is the turbo with the charge pipe pulled off, there was a large amount of oil build up.
Old Mar 20, 2013 | 11:57 AM
JBThrasher22's Avatar
Did you properly prime the turbo after the install?
Old Mar 20, 2013 | 01:33 PM
tomj77's Avatar
White smoke is coolent guys , blue smoke is oil
Old Mar 21, 2013 | 05:27 PM
Aleksey's Avatar
any updates?
Old Mar 22, 2013 | 12:17 AM
heinen02's Avatar
Just got done taking the turbo back off the car earlier tonight, I'm sending it back into ZZP to get fixed or replaced what ever they decided to do. They pretty much told me that it rarely ever happens that they send out a bad turbo, but i was unlucky enough to get the one that they did. after taking the turbo off i poured about a cup of oil out of the compressor side of the turbo. Happy that zzp is helping me out but sucks as im in Germany so by time it gets there and then send it back it could be a month or so before i get the new turbo.
Old Mar 22, 2013 | 07:17 AM
Chevycobaltss3's Avatar
When did you contact me? Never received a message!
Old Mar 22, 2013 | 08:52 AM
heinen02's Avatar
im never on here, so i found you on facebook and sent you some msgs on there.
Old Mar 22, 2013 | 10:29 AM
In order for me to see messages I have to be your friend .
Old Mar 22, 2013 | 11:47 AM
umrdyldo's Avatar
Is it sitting in your "other messages" box on Facebook?
Old Mar 22, 2013 | 01:37 PM
etnies's Avatar
You don't wanna deal with james anyway hes good at ripping people off. Cant say wether his tunes are any good. Paid for one and never got it
Old Mar 22, 2013 | 04:12 PM
You are a idiot..... I told you I'm not gonna build your engine... So ******* what. Get over it.. You came to me for a tune cu your Zzp tune was over boosting you. So I did a comp test and you had no comp in 4. You then asked can you install a tune into my ECM for warranty. So I did and you paid for it. ( listen and understand what the **** I'm writing because it seems you have no clue)
You paid for the tune..... The stock tune. I then said if you want me to tune your car, you can come down and I wouldn't charge you for a tune.... Did you come? **** no. You didn't... Is that my problem that your being a child because I said I am not gonna build your engine because you took so ******* long. So quit whining that I " took money from you" because I infact did not. Stop lying out of your ass.
Old Mar 22, 2013 | 04:18 PM
Terminator2's Avatar
Oil smoke is bright blue and smells like "burnt oil". Coolant smoke is white and reaks like burnt sugar.
Old Mar 22, 2013 | 04:45 PM
PsychoGenius's Avatar
/popcorn
