Can't get the valve cover off
Old Mar 27, 2009 | 11:13 AM
rm.lydon08's Avatar
How did you guys that removed your valve cover get it off. Theres no remaining bolts and it's just stuck there. Also, the little hose that runs from the valve cover to the turbo, how do you remove it from the turbo? I really got to figure this out beofr5e work at 4
Last edited by rm.lydon08; Mar 27, 2009 at 11:13 AM. Reason: Automerged Doublepost
Old Mar 27, 2009 | 11:15 AM
Terminator2's Avatar
You need a fuel line tool (like you use to change the fuel filter on a Ford truck) to remove the hose fitting from the valvecover. If you have all the bolts off it just needs to be lightly pryed in a couple spots the gasket is all that is holding it on now.
Old Mar 27, 2009 | 11:28 AM
FutureEcotecOwner's Avatar
Question: Why do you need/want the valve cover removed?
Old Mar 27, 2009 | 11:35 AM
He probably wants to powdercoat or paint it. That is what I think.
Old Mar 27, 2009 | 11:43 AM
Possibly. That just seems like too much damn work just to do that though.
Old Mar 27, 2009 | 11:58 AM
X2. The only way mine is coming off is if I do some valvetrain or cam upgrades.
Old Oct 11, 2009 | 03:22 PM
SportredSS's Avatar
Well, mine has two leaks and needs to be R\R..
Old Oct 12, 2009 | 03:09 AM
mkriebs's Avatar
I tried a fuel line tool, and it did NOT work. Maybe I had the wrong tool though. Its DEFINITELY a PITA though. Some people use screw drivers, but that messes up the hose. I decided to give up and not try any more, lol.
dennis69
Oct 20, 2015 04:49 PM
HEATON
Oct 16, 2015 07:21 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Trav3480
Sep 28, 2015 02:46 PM
SlowSaturn
Sep 28, 2015 11:03 AM
