Car starts, bogs, then dies
I have no idea whats wrong with my car this time. My silicone coupler from the cold charge pipe to the IM had a hole in it (long story) so I replaced it. Right after installing the new coupler I try to start the car and it stars then bogs a couple times and dies. The car stayed on long enough to throw the codes P0336,P2178, and P050A. I looked up the info on the cels but I have no idea what the problem is. When the car was running it was always misfiring at idle and would sometimes blow out white smoke. Does anyone have a clue what could be wrong with my car.
my car did some wierd stuff when I fixed a boost leak simalar to what your describing it didnt through a code though maybe try diconecting the battery for a little while and see if resetting the computer does anything
Mine sorta does the same thing since its gotten cold out. Sometimes it will start, chugs for a couple secs, then eventually die. Go to start it up on the second time and it starts like normal. Bit i dont have any smoke off of mine tho.
robk |
I'm getting bogging and slight misfires at startup but I think mine is evap related
Just looking at the codes One is for crankshaft sensor, one for idle speed at cold start and the other to too rich bank 1 This is where I check out cause it's above my head |
Originally Posted by Red_SS/TC
(Post 5492294)
p2178 - Fuel Trim System Rich at Cruise or Accel p050a - Cold Start Idle Air Control System Performance dont know what those mean. |
I had this happen to me, but supercharged, turned out to be a bad map sensor.
Originally Posted by 07BoostedG5
(Post 5492726)
I already tried resetting the battery and tried starting multiple times with no luck. |
yea, believe me it was a mess to trouble shoot, I checked just about everything from the fuel pump to the Tb. Plugged in the new map, started like a champ.
(Post 5492741)
lol o the precious memories
The choking on cold start-up is weird. Mine only chokes on start-up if let the key sit in the on position for a second or more. If i turn the key immediately to ignition it never seems to happen.
This morning when I started my car, it started hard. It barely idled for a few seconds then idled normal. The same time it was shooting black soot out of the tail pipe. What could it be. I have hp tuners but it's not throwing any codes.
Mine started rough and died. When I started her up the second time it was normal. No CEL and drivability was normal. Think the cold weather had a big factor. Below freezing weather FTL!!
this happened all the time to me when i had my ss.... i replaced the knock sensor, and maf sensor, and all was good, check ur fuel filter as well.
