Car starts, bogs, then dies
I have no idea whats wrong with my car this time. My silicone coupler from the cold charge pipe to the IM had a hole in it (long story) so I replaced it. Right after installing the new coupler I try to start the car and it stars then bogs a couple times and dies. The car stayed on long enough to throw the codes P0336,P2178, and P050A. I looked up the info on the cels but I have no idea what the problem is. When the car was running it was always misfiring at idle and would sometimes blow out white smoke. Does anyone have a clue what could be wrong with my car.
my car did some wierd stuff when I fixed a boost leak simalar to what your describing it didnt through a code though maybe try diconecting the battery for a little while and see if resetting the computer does anything
Mine sorta does the same thing since its gotten cold out. Sometimes it will start, chugs for a couple secs, then eventually die. Go to start it up on the second time and it starts like normal. Bit i dont have any smoke off of mine tho.
robk
robk
I'm getting bogging and slight misfires at startup but I think mine is evap related
Just looking at the codes
One is for crankshaft sensor, one for idle speed at cold start and the other to too rich bank 1
This is where I check out cause it's above my head
p2178 - Fuel Trim System Rich at Cruise or Accel
p050a - Cold Start Idle Air Control System Performance
dont know what those mean.
I already tried resetting the battery and tried starting multiple times with no luck.
The choking on cold start-up is weird. Mine only chokes on start-up if let the key sit in the on position for a second or more. If i turn the key immediately to ignition it never seems to happen.
This morning when I started my car, it started hard. It barely idled for a few seconds then idled normal. The same time it was shooting black soot out of the tail pipe. What could it be. I have hp tuners but it's not throwing any codes.
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
