Catless DP Trouble Fixed!!
Old Aug 15, 2010 | 01:33 PM
1SLOLT1's Avatar
Ok so i have done my research on here of people using spark plug non-foulers and others getting custome tunes to tune out the rear o2 sensor. Well since i have the GMS1 i figured I would try the Non-fouler's so i went to Kragen Auto Parts and bought the "HELP" Non-Foulers 18mm part number 42002 come in a pack of two. I disconnected the batterey first. I then threaded the o2 sensor in the non-fouler and it wont fit you have to drill it out I used 7/16 drill bit. I then took the second non-fouler and put them together i left the second non-fouler alone i didnt drill it out. I then threaded it into the DP and then installed the O2 sensor. I reconnected the batterey. I restarted the car let it run for 10 minutes and drove 30 miles to the racetrack and ran 15 passes then drove 30 miles back home and no CEL light......I was gettin the CEL without the Non-foulers after 20 miles. I would say this fixed my problem.
Old Aug 15, 2010 | 01:44 PM
b00sted06ss's Avatar
lol 15 passes? yeah right
Old Aug 15, 2010 | 04:07 PM
1SLOLT1's Avatar
Yeah my Bad I made 16 passes just counted all the timeslips
Old Aug 15, 2010 | 04:23 PM
slowstang's Avatar
Looks like you found a nice fix for that style downpipe. I'm currently running a ZZP downpipe and have 3k miles on it so far with no CEL.
Old Aug 15, 2010 | 05:01 PM
leoaa777's Avatar
A quiet track on a week night, sure 15 passes are doable. I have done about 11-13 on my ss-tc in one night, first 6 or so were back to back but them it got busy.
Oh yeah, what were your times?
Old Aug 15, 2010 | 05:03 PM
thats alot of passes, ive only done 3 in one night
Old Aug 15, 2010 | 05:46 PM
1SLOLT1's Avatar
Yeah it was slow last night so I could have got more passes but I took a break for a while.
I ran 13.7 @ 109.664 mph
Old Aug 15, 2010 | 06:44 PM
blackrocky's Avatar
nice numbers! how much is the motor putting out?
Old Aug 15, 2010 | 07:36 PM
1SLOLT1's Avatar
v
266 whp 284 wtq on mustang dyno without the down pipe installed
Old Aug 15, 2010 | 08:37 PM
northvibe's Avatar
wait if you drill it out did it take the threads out? or ???
Old Aug 15, 2010 | 08:42 PM
fakameanrepresent's Avatar
you most likely don't need 2 defouler, just use one. i have the MPX j shape defouler and its working perfect.
Old Aug 15, 2010 | 08:52 PM
1SLOLT1's Avatar
No didn't take out the threads but be careful cuz you could damage them when drilling it out.
Old Aug 16, 2010 | 05:07 PM
RoadconeTuning's Avatar
jesus, was that a 2.6 60ft or something?
i made 13passes in my mustang the first time i ever ran at the track, came in 2nd place in the bracket races that night too...
Old Aug 16, 2010 | 05:13 PM
SSlobalt's Avatar
Is the OP's DP a Megan or MPX?
Old Aug 16, 2010 | 05:24 PM
Berto09ss's Avatar
15 is reasonable..must of been a slow night
ive done like 7 at most?
Old Aug 16, 2010 | 05:49 PM
Wangspeed's Avatar
It can take up to a week for P013e or P420 to pop up.
Old Aug 16, 2010 | 07:31 PM
1SLOLT1's Avatar
Megan Racing DP
Yeah my best 60' was a 2.2 but I kept spinning bad once I shifted to 2nd gear.
Old Aug 16, 2010 | 07:50 PM
elecblue06's Avatar
it takes more then 20 miles for the sensor to reset in it's cycles.. thats not enough time to tell if it's worked.. you need to drive like a couple hundred miles
Old Aug 16, 2010 | 09:27 PM
1SLOLT1's Avatar
I was getting CEL I would say about 30 miles after driving i have now driven over 150 miles.......time will only tell I will keep you guys updated, but I hope it doesnt come back!!
Old Aug 22, 2010 | 02:07 AM
1SLOLT1's Avatar
Still no CEL its been a week almost 1K miles
Old Sep 12, 2010 | 03:15 AM
1SLOLT1's Avatar
Update: been a month over 1000 miles and still no CEL.
Old Sep 12, 2010 | 05:29 PM
T-Man's Avatar
Blasphemy! You have to buy a HAHN DP for the CEL to never come on!!!!!111
Old Sep 12, 2010 | 05:40 PM
nikemax21's Avatar
Well not everyone wants to spend $350+ on a downpipe just for the name hahn. I spent $215 on my zzp and got a free update from trifecta that disables the rear o2 sensor. So I hope with that purchuse of the hahn downpipe they also included at least $130 worth of lube with that raping.
Old Sep 12, 2010 | 10:06 PM
T-Man's Avatar
Apparently the joke was too clever for you.
Old Oct 9, 2010 | 07:33 PM
1SLOLT1's Avatar
Still no CEL
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
dieGone
Oct 1, 2015 06:27 PM
z28addiction
Sep 28, 2015 12:03 AM
