cel
Old Jun 26, 2011 | 07:07 PM
scopedmp5's Avatar
cel
Now after all the non sense that my car was doing, the cel finally came on. P0236,p013e and p2261.
under acceleration the car sometimes builds boost then dies out, and sometimes backfires. starting to **** me off but thats what i get for beating the **** out of it. gotta pay to play! lol
any help would be greatly appriciated!
maybe airleaks?
Old Jun 27, 2011 | 09:31 AM
Permafried-'s Avatar
P0236 = Turbo system performance
P2261 = https://www.cobaltss.net/forums/prob...-p2261-184458/
P013E = 02 sensor not reacting quickly enough if I remember correctly
Best place to start might with with the P2261 since the P0236 can be anything from that to a boost leak, bad MAP/TMAP, etc.
Old Jun 27, 2011 | 09:37 AM
ctn2mb's Avatar
maybe airleaks?
what mods do you have?
Old Jun 27, 2011 | 09:39 AM
CudaJoe's Avatar
he just put a new turbo in his car himself. its a stock turbo to replace his blown stock turbo.
Old Jun 27, 2011 | 09:41 AM
ctn2mb's Avatar
did these codes come on right after he installed it? or before? because I had 2 of the 3 before I got my turbo replaced a few days ago...
Old Jun 27, 2011 | 09:44 AM
ctn2mb's Avatar
but if you had a CEL pop for a P2261 then take it to the dealer because there is a bulletin out for it, they will replace your BPV or the vacuum tank.
Old Jun 27, 2011 | 09:48 AM
I'm assuming once that one is resolved the 0236 should just go away unless there's a leak from the installation of the turbo itself.
Old Jun 27, 2011 | 09:50 AM
CudaJoe's Avatar
well last week he made a thread saying he just finally got the Turbo and installed it so im assuming these codes didnt appear till today.
Old Jun 27, 2011 | 09:55 AM
scopedmp5's Avatar
im a tech at the dealer lol. but yes anyways the codes were present before hand. the p2261 and p2236 were there before. just a gms1 and zzp catless dp. i didnt get a chance to bring it in yet. probably will over lunch. holds vacuum like it should. just need to look at current data
Old Jun 27, 2011 | 10:28 AM
scopedmp5's Avatar
what i dont get is the car doesnt always act up. there are times i can get on the gas and runs perfectly fine, and other times she will act up
nice it was warrantied but i kinda wish i would have put a different turbo on......oh well
Old Jun 27, 2011 | 10:44 AM
BlueTurbo's Avatar
You sound like a lube tech. You install the O2 sensors properly? Didn't damage the element? Slow switching from rich to lean pretty much means either exhaust leak or bad sensor.
Check out that PI for the P2261, as for the P0236, a vacuum leak will set the code. Check the charge air cooler.
Old Jun 27, 2011 | 10:45 AM
BartSS's Avatar
isnt the 0236 your map sensor... that could have blown.. happened to mine and i swapped it and the intermittent boost went away
Old Jun 27, 2011 | 10:49 AM
ctn2mb's Avatar
I bet... It's the lower sensor and make sure the vacuum line that goes to the lower charge pipe is on all the way...
Old Jun 27, 2011 | 10:58 AM
scopedmp5's Avatar
ill check the PI over lunch today, and no i am not a lube tech. gm for three years then hyundai. bye bye hyundai franchise this thursday lmao. The only gm vehicles i got to screw with the last two years were basically mine. they are picky about handing out the other gm techs gravy......lmao.. anyways is there a 5v reference or a way to ohm out the sensor/spec for the sensor itself
Old Jun 27, 2011 | 11:02 AM
scopedmp5's Avatar
o2 sensor seemed a bit fauled when i had it out. or however the hell it is spelled. anyways, there are no exhaust leaks at this moment. the car still reaches peak boost but doesnt always hold there. "assuming fail safe when that sensor on the charged piping takes a ****"
carbon and what not on the valves. is it safe to run seafoam or engine top cleaner through these motors>?
Old Jun 27, 2011 | 11:04 AM
scopedmp5's Avatar
no hoses are pinched off. vacuum line on the lower cp is seated fine
Old Jun 27, 2011 | 11:13 AM
ctn2mb's Avatar
I'm assuming the lower sensor wires are loose. Mine did it as well till I got the connections fixed.
Old Jun 27, 2011 | 11:14 AM
scopedmp5's Avatar
the terminals or the soldered connections at the wires
Old Jun 27, 2011 | 11:17 AM
ctn2mb's Avatar
connections at the wires, guy was able to pull mine out easily lmao. and now it doesn't do it anymore.
Old Jun 27, 2011 | 08:25 PM
I shouldn't have posted in this thread. Mine threw a p0236 for the 6th time since I bought it (numerous things fixed) and after driving it hard finally set a P2261. This thing is pissing me off now. Back to the dealer yet again tomorrow I guess it may as well setup a tent there.
Old Jun 27, 2011 | 09:12 PM
scopedmp5's Avatar
Blown sensor. Fixed up. The o2 sensor was fauled. Graphed the data of both o2 sensors. One stuck rich. Also checked the vacuum tank. Held vacuum and didn't bleed off. I got freakin lucky lol
Old Jun 27, 2011 | 09:16 PM
ctn2mb's Avatar
So it was the sensor?
Old Jun 27, 2011 | 09:44 PM
scopedmp5's Avatar
Yes sir, and the o2 sensor for the other code
Old Jun 28, 2011 | 07:32 AM
ctn2mb's Avatar
That's the same thing that happened to mine, with exception of the o2 code lol
Old Jun 28, 2011 | 10:14 AM
CEL was still on this morning, in it went. Told the dealer about the TSB on P2261, as well as to look at the MAP, TMAP, and the boost and BPV solenoids. Since it's intermittent, my guess is a sensor or solenoid is failing the start-up diagnostic. It drove fine today, full boost, BPV was opening, turbo was fine....so I can't imagine it's anything else.
