Check your turbo coolant pipes
Old Feb 15, 2012 | 11:50 PM
YelloEye's Avatar
So Friday night heading to dinner I noticed a smell of coolant coming from the engine bay and decided that though I wasn't low on coolant, I should definitely figure out where that smell was coming from. Saturday rolls around and I park the car in the garage at work, hour later there's a small puddle of DexCool on the ground just behind the motor. Well she didn't lose much coolant after that, just a bit while the system was pressurized. Promptly after work I snagged 4 gallons of distilled water to ensure I would make it to my friend's house so we could put it up on ramps and figure out where it was coming from.
I get it to his house and I can hear coolant hitting either the turbo or exhaust manifold. We pressurize the system with an air compressor and discover that there is coolant spraying onto the gasket between the turbo and exhaust manifold. Too dark to do anything so we pick it up the next day. I buy the banjo bolt gaskets and pull the turbo coolant return pipe off to discover this nice little gash in it:
Turns out the manifold gasket actually cut the pipe somehow, so I bent the gasket down flat so it wouldn't rub any more and tossed some QuikSteel onto the cut spot:
I spoke with a dealership before I pulled everything apart and they said the coolant pipe wouldn't be covered under the 100k mi powertrain warranty. So I elected to just patch and replace it myself. Ordered a new pipe from GMpartsdirect.com for $70shipped and will hopefully be putting that on next weekend.
TL;DR? Exhaust manifold to Turbo gasket cut turbo coolant return pipe, GM said no warranty on that part, bent the gasket, patched pipe myself and will be replacing with an OEM piece soon.
Old Feb 15, 2012 | 11:55 PM
Validater's Avatar
Nice fix. pretty ****ing stupid that that isn't covered under warranty.
Old Feb 16, 2012 | 12:02 AM
YelloEye's Avatar
That's just what the service writer said when I asked, for the record I did not take my car in. They wanted $120 for diag if it wasn't covered. Twas cheaper for me to just buy the part and do it myself than chance that it wasn't.
Old Feb 16, 2012 | 12:03 AM
Frogstofall's Avatar
That JB Weld doesn't work all that well for these kinds of things. Luckily you got the new one on the way! I just looked at mine this weekend while doing the clutch. Good info here.
Old Feb 16, 2012 | 12:08 AM
tomj77's Avatar
its part of the engine system, it should be covered
Old Feb 16, 2012 | 12:09 AM
YelloEye's Avatar
Yeah, max operating temp is 500*F. Sitting 1/4" off the exhaust manifold might not be so great for it. It'll only be there till the new one gets here.
Too late now, they won't touch it with QuikSteel on it.
Old Feb 16, 2012 | 07:43 AM
CudaJoe's Avatar
BS they say its not covered. let all the coolant run out and the motor blow then bring it in and ask if its covered? lol.
Old Feb 16, 2012 | 09:13 AM
user 72239's Avatar
Drastic, but effective none the less haha
Old Feb 16, 2012 | 09:25 AM
northvibe's Avatar
It is fairly obvious if you read the PT warranty it is not covered....
Engine
Cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers valve covers, oil pan, seals, gaskets, turbocharger, supercharger and all internal lubricated parts as well as manifolds, flywheel, water pump, harmonic balancer and engine mount. Timing belts are covered until the first scheduled maintenance interval.
Engine: 2010 Chevrolet vehicles
All internally lubricated parts, engine oil cooling hoses, lines and radiators. Also included are all actuators and electrical components internal to the engine (i.e., Active Fuel Management Valve Lifter Oil Manifold, etc.), cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, manifolds, flywheel, water pump, harmonic balancer, engine mount, starter motor, turbocharger and supercharger. Timing belts are covered until the first scheduled maintenance interval. Exclusions: Excluded from the powertrain coverage are sensors, wiring, connectors, engine radiator, coolant hoses, coolant and heater core. Coverage on the engine cooling system begins at the inlet to the water pump and ends with the thermostat housing and/or outlet that attaches to the return hose. Also excluded are the entire pressurized fuel system (in-tank fuel pump, pressure lines, fuel rail(s), regulator, injectors and return line) as well as the Engine/Powertrain Control Module and/or module programming.
Chevy Warranty Information | Owners | Chevrolet
Sucks yes, I agree, but the internals of a turbo etc are covered. So you give a trade off. The expensive stuff is covered but the cheap easy to have break stuff is not. Glad you found the break before **** hit the fan though.
Old Feb 16, 2012 | 09:26 AM
Dart_SI's Avatar
I will check mine during the turbo swap.
Oh yea, pics aren't working for me.
Old Feb 16, 2012 | 09:56 AM
YelloEye's Avatar
Interesting, anybody else not seeing the pictures?
Old Feb 16, 2012 | 09:57 AM
Dart_SI's Avatar
I see it now.
Old Feb 16, 2012 | 10:20 AM
JacBlackSS/TC's Avatar
yeah GM warranty sucks big time
Old Feb 16, 2012 | 10:50 AM
emiller's Avatar
I doubt many places would warranty a hose.
Old Feb 16, 2012 | 10:53 AM
northvibe's Avatar
If you aren't under 36k 3year, ya no other car company would...it is even listed in the warranty booklet that it is NOT covered...
Old Feb 16, 2012 | 12:56 PM
sponge14's Avatar
Yes it does, and not just in regards to this issue....
Old Feb 16, 2012 | 01:07 PM
SSlobalt's Avatar
Ima go check to see if mine's rubbing.
Old Feb 16, 2012 | 01:10 PM
SSlobalt's Avatar
Yeah, everyone is always saying "Honda does this for you" and "Honda does that for you. They're so great." The reality is that Honda is just like every other car company. They wouldn't cover this, either. I can tell you that from experience. It's all about dealership customer service at that point. If you bought your car at the dealer you're getting serviced at, they'll generally help you out with things like this. To this day, the best warranty I have ever had was on a 2000 Altima SE. Nissan replaced seals on that thing all the way to 120K and it leaked out of quite a few of them. That Nissan dealership spoiled me for the rest of my life.
Old Feb 16, 2012 | 02:13 PM
oh trust me i know i learned the hard way
Old Feb 16, 2012 | 06:46 PM
northvibe's Avatar
EXACTLY. It is the dealership.
Old Feb 16, 2012 | 07:18 PM
YelloEye's Avatar
Meh, I'm not worried about a $70 part out of my pocket. Car has been great to me for the most part. Really glad GMPD exists, guys are good on pricing for sure.
Old Feb 17, 2012 | 08:16 AM
DPveritasGold's Avatar
Interesting seeing those pictures. I noticed a gash like that on mine, but it wasn't in an actual pipe, it was a piece of metal that appeared to be protecting the pipe. I'm not sure what it is, but when I saw that it wasn't on an actual pipe I just didn't worry about it.
Old Feb 17, 2012 | 08:44 AM
Prestige_Worldwide's Avatar
I have found if you are over your 3yr/36k warranty 99% of the time if your **** isn't blowing up they won't cover it. Save yourself the headache and just fix it yourself or take it somewhere else. Dealerships are not worth the hassle.
Most of the time you will leave with a bill for more than the part would have cost in the end with nothing done.
Old Feb 17, 2012 | 12:19 PM
sponge14's Avatar
I'll second that motion... Even IF you are under 3/36k you still have a fight with them
Old Feb 17, 2012 | 07:54 PM
YelloEye's Avatar
The metal ducting surrounding the flex portion of mine has a gash in it too, no big deal though. It's heat shielding and works fine.
