Crank sensor location
Old Feb 11, 2014 | 04:49 PM
paintballerr78's Avatar
Does anyone know if the crank position sensor is the sensor located almost directly underneath the oil filter on a lnf? I have to change mine and want to make sure this is it before i go and remove it.
For some odd reason my car sputters terribly when idling from 500-1500 about itll bounce around and when i give it throttle the fuel pressure drops to 70 then the car shuts off.
Old Feb 11, 2014 | 06:07 PM
kzak104's Avatar
behind starter
Old Feb 11, 2014 | 08:41 PM
Balt_2.2's Avatar
You'll also have to do a crank sensor relearn if you pull it out. Whether you put a new one in or not.
Old Feb 11, 2014 | 11:48 PM
alright so looks like ill have to remove the starter...and im not sure were that relearn comment came into play i was trying to find out where its at so.....
Old Feb 11, 2014 | 11:52 PM
Balt_2.2's Avatar
I was just saying. I didn't know if you knew that or not. Sorry for getting off topic.
Old Feb 12, 2014 | 12:09 AM
ItalianJoe1's Avatar
I have usually done them from the top and not removed anything but the sensor, but I don't know about the LNF manifold and clearance issues with that. I know on an LSJ I can pull the sensor working from the top with nothing but the one bolt that holds it in to remove.
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
Stuff
Oct 1, 2015 05:47 PM
jmelton327
Sep 26, 2015 10:04 PM
