Custom CAI with paper filter
I put this together a while back. I made use of an S2000 stock air filter. The big paper cone flows more air than stock and fits right under the headlight. I insist on filtering my intake with paper elements. Was about $120 in the end. I tried to keep it as cheap as possible in case it didn't work. That's why I settled for a blue hose. It's been running perfectly since I put it on.
This pic is when I first put it together. Yes, I use hose clamps for all connections. http://i1157.photobucket.com/albums/...ps6074e31d.jpg Parts list: MAF pipe 3" Spectre 9405 Silicone elbow 3" 45 degree Aluminum pipe 3" 2' Silicone elbow 3.25" to 3" 45 degree - Pipe to filter Air filter WIX 42726 (Honda S2000) Clamp 3.25" T-bolt Clamp 3" T-bolt - 3 I now use a 49003 filter (newer S2000s, bigger engines) |
And did you tune for it?
(Post 7466400)
Wow I have a hard time believing that didn't effect stft and ltft I thought the maf was pretty sensitive
Originally Posted by LNFTX
(Post 7466409)
Prior to the CAI, I saw spikes in the STFT just as high, but a 7.03 LTFT. |
And nothing needed to be adjusted?? :lol: :lol:
Originally Posted by 09CobaltSS1
(Post 7466426)
As close to zero as possible. A +/-2% total overage can be considered "acceptable" but as close to zero as possible is the goal.
Might wanna look into a hydroshield
Interesting, thanks for the idea.
(Post 7466430)
I was thinking maybe, constructing something between the headlight bracket and bumper to divert water away from the cai filter. Looks good for that price.
Water comes in around the headlights in hard rains. I would never put a paper filter there. I have a Hahn that sits there and my hydro shield gets damp.
(Post 7466438)
Originally Posted by ATOMbomb
(Post 7466437)
nice intake its always fun to build your own parts. Any shield has be better than nothing, u could always do some testing with a hose and see.
Does that filter have a 3" inlet?
Originally Posted by Solaris99
(Post 7466442)
Would a heat shield over the top of the filter protect it enough? The kind that is like half of the filter.
Originally Posted by no_ss
(Post 7466489)
just buy the hydroshield, they're 20$
Originally Posted by footballplaya3k
(Post 7466454)
(Post 7466510)
They are not water proof. Adding something like this would just be added protection. Wonder how hard it would be to build almost like a ram air for the cai and have the opening connect Above the fog light.
I just ordered a Hydro-Shield for an X-1022 filter, since it's the biggest they have.
X-1022 - 5'' filter, 6.5'' Base, 8'' Tall, 5.5'' Inverted Top Pretty close to what I'm using. 49003 - 3.25" filter, 6.25" Base, 9" tall (filter section only), 4.5" top. |
The set up looks not to bad at all
Originally Posted by mr bill
(Post 7466562)
http://i1157.photobucket.com/albums/...ps14c812a0.jpg |
The X-1038 fits perfectly. Thanks again for the advice.
http://i1157.photobucket.com/albums/...ps28633b9d.jpg |
