Custom CAI with paper filter
I put this together a while back. I made use of an S2000 stock air filter. The big paper cone flows more air than stock and fits right under the headlight. I insist on filtering my intake with paper elements. Was about $120 in the end. I tried to keep it as cheap as possible in case it didn't work. That's why I settled for a blue hose. It's been running perfectly since I put it on.
This pic is when I first put it together. Yes, I use hose clamps for all connections.
Parts list:
MAF pipe 3" Spectre 9405
Silicone elbow 3" 45 degree
Aluminum pipe 3" 2'
Silicone elbow 3.25" to 3" 45 degree - Pipe to filter
Air filter WIX 42726 (Honda S2000)
Clamp 3.25" T-bolt
Clamp 3" T-bolt - 3
I now use a 49003 filter (newer S2000s, bigger engines)
Parts list:
Aluminum pipe 3" 2'
Clamp 3.25" T-bolt
Clamp 3" T-bolt - 3
Prior to the CAI, I saw spikes in the STFT just as high, but a 7.03 LTFT.
I just ordered a Hydro-Shield for an X-1022 filter, since it's the biggest they have.
X-1022 - 5'' filter, 6.5'' Base, 8'' Tall, 5.5'' Inverted Top
Pretty close to what I'm using.
49003 - 3.25" filter, 6.25" Base, 9" tall (filter section only), 4.5" top.
