DC Strut Tower Bar Clearance?
I have a 08 SS/TC with dejon charge pipes and HKS Bov I was looking at buying a DC strut tower bar but I didn't know if it'll work with piping anyone have any insight on this before I fork out the money??
^^^ This
I will get getting rotated tranny mounts this spring. If you have a CAI, you could also look into an Ingalls Stiffy TD. Unfortunately a TD wont work with the stock air box or an SRI.
I know that Eibach makes a 29 mm front sway bar... The LNF stock is 23 or 24, cant remember.... Though I dont know if this would help cuz I always heard you wanted a smaller sway bar on a FWD car...
Im sure someone else will chime in to confirm or correct me haha Great thing about this site is knowledge
But no strut tower bars/braces work on LNF's to my knowledge.
Driver mod maybe? lol jk
Do you know what all your tune entails? maybe have a re-tune and get a reduced boost 1st gear and some more fine tuning on there to make the boost not come in at full force??? I know ZZP can do this, they are doing my car in the spring. I know depending on pavement, my car stock spins from 35-40 if its cement... Other things you can try is let some air out of the tires... I usually run mine 32-35 though they are rated at 51 max psi... Ive had them as low as 26 before the TPMS started bitching at me haha
BTW, CAB's = Control Arm Bushings...
You could do poly, but I hated poly back when I had my camaro... dont know how it is on cobalts or if they offer other CAB's than poly...
I'm running 33psi ish almost all the time i'm not done the tuning part yet i'm still looking to up boost but i gotta solve the traction issues first i'm gonna run 25psi of boost looking for 340 whp and 360wtq but all that means nothing if i go nowhere
33 psi is one of the reasons why you are spinning. I always run 35 or so while driving to work an back. But when I go out to do some pulls or run it, I lower it to 20 - 24 psi and it helps alot.
It's hard putting down power on 18 inch rims. But I agree why spend money on power if you can't put it down. Try getting some traction bars
Have you contacted Powell about what your looking at/for? They have a few things I haven't seen other places offer such as SFC's.... start there and get his opinion, John is a wealth of knowledge I have come to learn...
33psi on the stock turbo lmao.....might wanna turn that waaaaaay down before your buying more then traction mods.
No strut bars clear the lnf...eibach front is a waste of money
Im sorry I was talking about the psi in the tires. I was trying to tell him if he ran lower tire pressure it would help with the spinning.
