does yours look like this
Old Feb 20, 2011 | 12:57 PM
turboss09's Avatar
Every time i change my oil/oil filter the oil filter looks deformed when i pull it out. it looks similar to the pics in this thread, https://www.cobaltss.net/forums/gene...ck-out-122792/
Is this normal, i change my oil/filter every 3000 miles very strict about doing that. What does everybody's look like similar to those pics or like a brand new filter just covered in old oil? Also i don't believe im over tightening oil cap, i just snug it up nothing crazy.
Old Feb 20, 2011 | 01:21 PM
tomj77's Avatar
mine did that last time i changed oil. but the first bunch of times it looked normal, dont know what caused it
Old Feb 20, 2011 | 01:31 PM
DomDiggity's Avatar
Mine has looked like that the past three times I've done it. My ic pump was out and I replaced it. I hope that's why mine was doing it but I haven't changed my oil since
Old Feb 20, 2011 | 01:35 PM
DomDiggity's Avatar
I've done my own oil changes for 5 years since I got the car at 0 miles. and have replaced the filter everytime
Old Feb 20, 2011 | 01:39 PM
gotboost?17's Avatar
Nothin Stock
ill c next time they do mine dint really pay attention the other times
Old Feb 20, 2011 | 02:12 PM
shredout's Avatar
mine looks like that every time. i change every 3k to 4k depending on how busy or broke i am. i may be over tightening though...
Old Feb 20, 2011 | 02:49 PM
northvibe's Avatar
are you using the oem acdelco filters?
Mine will be slightly diagonal but not bent like in the link you posted. But I use the oem acdelco ones.
Old Feb 20, 2011 | 02:58 PM
BlackARCA06's Avatar
I changed my oil yesterday and mine looked like that. Its the first time its done that. I change every 3K. Might change up my oil filter next time, but was told its normal.
Old Feb 20, 2011 | 03:04 PM
joeyjetta46's Avatar
its pretty normal to look like that....think about it is soaks up in oil and the filter gets wet so of course its gonna look like that.... think about taking a sheet of paper and wetting it lol but even though it does look like that it still filters the oil
Old Feb 20, 2011 | 06:06 PM
PrincessTurbo's Avatar
^ professional mechanic right their .. Don't I know you as an oil filter engineer over on the Jeggs forum ..
Old Feb 20, 2011 | 06:28 PM
D-mac's Avatar
Buy Delco filters
Old Feb 20, 2011 | 06:38 PM
i am a mechanic though LOL
Old Feb 20, 2011 | 09:33 PM
cmiller8006's Avatar
The filters are designed to crush a certain amount like that. Its normal like most have said.
Old Feb 20, 2011 | 09:37 PM
06SIBLT's Avatar
Seems normal, however what type of filter you using? Pureolator PureOne will crush, I started using the mobilone filter, doesn't crush, it actually has more capacity and filtration rate, about ten dollars more, however never crushes and seems to work better.
Old Feb 20, 2011 | 09:42 PM
OiangeSS's Avatar
every filter that is made like this does it i worked for ford for 2 years the 4 banger fusions have filters like ours but they are located at the bottom of the engine(pretty messy oil changes bc the cap holds alot of oil) all the fusion ones i have seen do it too like joey said its normal nothing to stress about
Old Feb 20, 2011 | 09:47 PM
09BlueBaltSS's Avatar
Mine has never wrinkled like that. I change at 4k miles and use PureOne filters
Old Feb 21, 2011 | 07:16 AM
well their could be another reason...when people beat on the car... the oil would get hot and when it goes through the filter at a certain temperature it could affect it...but for majority of the cars that use cartridge... they all come out the same... hence why they would say 3,000 for every oil change... even thought the oil filter can only last 3,000 miles and oil can last like 10,000 miles.... in my opinion i still recommend changin it every 3,000 so the oil gets filtered and cleaned out proper not sending any dirt or deposites in the motor and doesnt affect the lubrication to the motor
