Dual Disk Clutch Research Almost Complete!
Hi everyone! I am very excited to report that my team is about to fit a dual disk clutch in my LNF cobalt ss. I got a LSJ Flywheel to make measurements and everything looks very promising but I need to know if the LSJ and LNF flywheels are Identical, if not, then I need to know what are the differences. I will post pictures and video for the install.
No, this is something else, we have been researching for a while now and we have now the right combo. We are making some final confirmations and if both flywheels are identical or at least compatible with each other, we will be installing/documenting everything once we start the installation!
i would imagine it would work just fine considering the GMPP clutch upgrade for an LSJ is a LNF clutch isnt it? also everyone upgrades to the LNF TOB too... Clutchmasters doesnt list either of their twin disks for the LNF... hmm... i wonder what the deal is?
*edit* just emailed them to find out lol
idk if they wear all that quickly, i think people just cant drive... my buddy has a exedy twin in his GTO and its got 60K miles or more on it and a NUMBER of street tire passes on 19's as well as a record setting pas for a bolt on LS1 GTO... it had been in two cars prior to that and its dead quiet at idle, you dont hear the floater plates banging around... now in my buddies Del Sol it has some LOUD floater plates that bang the whole time the clutch is in ...
clutchmasters makes a twin disk for the LSJ. it's possible that it might work on the LNF as well since it comes with the flywheel and everything
Who does "we" consist of?
What's the advantage of a twin disk clutch setup?
2. This set up will weight less than any single clutch set up, because of this the engine will rev faster.
3. The torque is applied in 2 stages as you apply your clutch, this benefits the transmission.
4. This will be the only clutch you would need, we have not rated how much torque it will hold more than 500 for sure
sounds like a good plan... have yall figured out a price?
It will fit just fine.
