dyno results
dyno results
So I had my car dynod today at the ced meet. I put down 283hp and 296tq. My afr was at 13.1. I already talked to a few people at the meet about it and they said I should have been a bit higher. What do you guys think. Mods in sig
They said I should be around 300hp. But I'm happy with the results. An hhr with just a stage kit dynoed at 257hp and 276tq. So I guess the exhaust and charge pipes help. I might throw hp tuners on top of the stage kit just to get a little more but ill see
lol but not bad numbers depending on what kinda dyno and what the baseline numbers where... its more the increase on the same dyno than the final numbers... like everyone elce said calibration for numbers are all diffrent.
Hp sounds about right if not a little high for 290 rated crank Hp. Torque seems right on the money for the stage kits rated output on the HHR. A/F is too damn lean to make much more than that. Needs to be richened up some.
My baseline #s for my HHR SS were,
1st pull - 238.28HP/260.87TQ
2nd pull - 245.83HP/261.90TQ
3rd pull - 237.59HP/252.88TQ
These pulls were back to back with no cooldown and they were on a dynojet. I will be re-dynoing this weekend at the same dyno and the only change I have made is the Stage kit.
What did stock HHR SS or Cobalt SS/TCs put down on that dyno. Most make 240 whp or so SAE stock. That dyno may read a little low but maybe it is worth only 20 whp or stock we need so see what someone made on that dyno stock.
