Dyno Tested: Vacuum Tank Bypass mod
So I decided to try the Vacuum Tank Bypass mod that can be found here...somewhere
Did the first pull completely bone stock and made: 243.5 whp @ 5523 rpm 243.2 wtq @ 2678 rpm Bypassed the vacuum tank and made: 250.8 whp @ 5454 rpm 254 wtq @ 2747 rpm In my opinion, the gains are well worth the 5 minutes it takes to do the mod. I also think I have pinned down what the vacuum tank actually does. IT COMBATS TORQUE STEER. If you read any car magazine comparisons of fwd turbo cars they always whine and moan about torque steer. So, if boost comes on slower, there is less torque steer. My car now has 0 lag and it doesn't bog down in corners and prevent the car from making boost like it used to. Picture of the dyno graph (Black=before, red=after) http://i574.photobucket.com/albums/s...g/P1000667.jpg Here's a video of the dyno run :cssNET: http://www.youtube.com/watch?v=TeBXz4ngcUs |
this is relevant to my interests
The hp increase could also be due to the engine being warmer in the 2nd pull and not due to the bypass mod, not the first time the lnf makes more hp on the 2nd or 3rd dyno pull.
Regardless, lag is essentially non-existent now and the car definitely feels faster.
When I bypassed it for a few days my fuel trims suffered.
Hmmm did you tune it out or did you plug the lines back into the tank?
Interesting...
Sub'd Yeah, I'd be interested to know the details of the dyno session so that can be ruled out. (How long it sat before you all started, how long between stock pull and tank bypass pull, etc) That's surprising that it would make any change besides a response improvement. |
Seemed to run a decent amount richer over much of the rpm range. Dont know how that could make it have more power though....
Originally Posted by alex_mcg
(Post 4781455)
Originally Posted by Terminator2
(Post 4782543)
See how the A/F is about 13.0 in the midrange vs 14.0 on the first run that is why there is a power gain. All the Vac tank does is it stores air so that when you let off the throttle or get on the throttle it opens and closes the BPV much more smoothly.
Originally Posted by ctn3mb
(Post 4782784)
i have a question term... would you say this would be a bad mod? or a good one... seems like one that you could do and retune your car vs the A/F
I did it to my car and what seems to happen is the BPV does not open as quickly as it should and that results in some mild compressor surge when letting off the throttle. I see no logical reason that this mod would change the A/F mixture unless a vacuum leak was introduced in the process. My commanded and actual A/F was always the same with or without the vacuum tank hooked up. All the vacuum tank does is to provide the BPV with a more consistant supply of air to either open or close it that is all it does. Chances are on his second run there was a little extra enrichment being added by the ECM to the normal PE Lambda value. That is the only reason the A/F should change in this situation. |
Just try the mod for yourself. I for one love the way the car pulls now.
I don't think anyone is a fan of turbo lag. |
(Post 4782992)
Was this done on a stock tune car too?
(Post 4783071)
The only lag we have the ETC lag really. It takes a full second from the time you go WOT until the throttle is open all the way to 100%. Made no difference on my car except it felt rough when letting off the throttle sometimes.
After watching the video again, I noticed their computer screen said my car spiked and held at 20 psi for a bit. I'm not sure if this is accurate because there was a sky redline there running a trifecta tune that read 5 psi higher than what his gauge showed. |
(Post 4781455)
(Post 4783100)
I had none of that. Just no lag. If I get the time, I'll try and make a video. That is if I can get someone squished behind my seat to hold a camera. So you can see how the car accelerates and how the boost comes on.
Originally Posted by BYT*SS*TURBO
(Post 4783090)
Maybe on a stock LNF the mod works but with a tuned LNF the actual tune is controlling the boost. I dont have a clue im just throwing out some suggestions. I have been contemplating doing this myself but my SS is trifecta tuned at 23.5 psi.
My questions: Is safe to do on a tuned LNF? Is it worth doing on a tuned LNF? (any HP is worth it to me as long as it is safe HP) Do i have to retune on my tuned LNF? |
Originally Posted by dflannery
(Post 4881194)
Originally Posted by mongorat427
(Post 4881447)
I did it on mine and then data logged it and sent the logs to Vince at Trifecta to have my tune adjusted for the higher boost. Im spiking around 25 a holding at 23 -24. It screams but I want to retune it with the adjustments from Vince before I take it to the track
(Post 4881194)
(Post 4881730)
Did you dyno it before and after the vacuum tank delete?
If you are stock, then maybe.
But if you are already going to tune, why not just tune it right and have your car run properly and blow off properly. High boost is ok until it has nowhere to go and blows through piping because it cannot release properly |
the sky redline and solstice gxp do not have this vacuum tank and i assume are running the same bpv? the connection is straight from the intake, about 2 in of tube. so they are running this stock. of course they may have a different stock tune that compensates for this, but that i dont know. but as someone said earlier maybe for the torque steer from the fwd just my 2 cents tho...
Originally Posted by gameguy69500
(Post 4882612)
