E-85
iam broke was the ginny pig and test different mix of e85 on his car the best performance came from a 50/50 mix. there is a couple threads on heard just use the search button
^^^ thanks brett. im running a 50/50 mix of e85 and 91 and my car loves it. pulls soo much harder than before
Even raising the fuel pressure via Trifecta to 2700 psi I ran out of injection window in the 4500 rpm high load areas on E85 and went too lean. Tripped a low fuel pressure & reduced engine power CEL at 6k also.
Tuned for 1:1 E85 & 93 is the fastest for me. Ya, there are threads on here and the HPT forum as well as GMSC that I keep updating with some logs & screencaps.
The last E85 pull & data are here...
Code:
http://www.hptuners.com/forum/showpost.php?p=230001&postcount=370
Absolutely! Motor will run poorly if at all, and even if the motor did run perfectly fine, without the propper setup you will not net any of the benifits that the e-85 could give you. Which is generally MUCH more timing. I think Iam Broke is running something like 20* max timing up top. I'm sure he can explain in much better detail.
A 1:1 mix of E85 and E10 93 octane requires about a 14% positive shift to get the A/F ratio (Lambda) correct.
I run 23* from around 4500 rpm up, I could run more but it gets too hard on the rod bearings I'm told.
YOU CANNOT RUN IT WITHOUT A TUNE!
It will shift the LTFT's to the point of a CEL and would run like crap.
The only time the LNF goes open loop is on a CEL or if the Air Load is > than around 230% as near as I can tell.
I'm open loop in most of my hard pulls up until around 5500 rpm. You have to have the MAF correction table dialed in well to maintain a good AFR. Mine prefers .89 on the 48% E mix. (1:1)
Another AZ TC corn sipper here
I've had great success with only using a 4:1 mixture but alas, it's time for more
Yo FF Ace, guess the Ethanol/Gas mix is better than the meth after all, eh?
And that is correct, if it wasn't for IAB, I'd have never tried mixing. After the first couple of times we spoke about it and I saw his results, I had to try it!
Thanks Tom!
Thanks Tom!
Thanks Tom!
Thanks Tom!
09TcSedan
17
May 4, 2012 11:09 AM
