Engine Build
Ok guys, I know some of you may hate me because over the past month I've opened a few threads regarding individual parts, but now I've decided to open a thread about all the parts I want to buy to explain what I want to do exactly to my engine once and forever, because I'm hoping to get the right advices from people that know much more than me about it, and I know that they are a lot out there. Most of you know that I own two 2009 T/Cs, and that I intend to keep one for daily driving by installing just bolts on and a tune (from BYT) and to build the other one to the extreme to start using it for fun.
- On the one to be kept as DD I have the BC coilovers, and I want to get all Hahn bolts on, such as catless downpipe and catback exhaust, Hahn CAI, Hahn FMIC and charge pipes, and a tune from BYT. - On the one that I want to build for fun I already have: AutoWerks turbo kit 55/57 with catless downpipe Custom exhaust built by BYT Hahn FMIC with charge pipes (the upper one is the one that came with the AutoWerks kit) OTTP stage 2 transmission mounts TTR upper motor mount Clutchmaster Stage 4 clutch Clutchmaster flywheel H&R 15mm wheel spacer in the front H&R 5mm wheel spacer in the rear Pedders Xa Coilovers with camber plates Eibach front and rear anti sway bars TTR rack spacer R1 Concept premium rotors drilled and slotted Hawk HP+ pads ZZP brake lines Sparco grip pedals TWM sts with weighted knob, base bushings and cable clamp Momo Pitstop carbon fiber e-brake SS floor mats from Modern Performance Gauges from Black Cat Customs ZZP triple A-Pillar pod with Autometer C2 gauges (not yet installed) BuyHIDs dual cluster gauge pod with Autometer C2 gauges (not yet installed) Sparco black seat belt covers front and rear After the winter I intend to build the engine, and I'm asking advices because I have to start saving from now so I would like to know what I will need. What I'm thinking is: - Wiseco pistons - Carrillo H-Beam rods - Darton sleeves (not yet sure about it) - ZZP ported head/cam combo - Supertech .5mm oversized inconel valves - Meth kit - Level 5 axles from DriveShaftShop - ZZP Stage 2 transmission I have a question and a doubt. Question: TTR sells the 88mm wiseco for the LNF. I would love to bore my engine. Did anybody do it? How is the car running? I've spoke to Darton and they told me that I can send them the pistons and they will bore their sleeves for them. Would the block get too weak? Keep on mind that I don't floor often. Doubt: Can I run the oversized valves with the ZZP camshafts? Did anybody do it? How is the car running? My goal would be to reach 600whp. That would be great, but if I reach 550whp would still be fine. I really thank you guys in advance for your help and advices. I hope I'm not getting too annoying, but before spending this kind of money, I want to be sure of what I'm getting Christian |
For the dd get the treadstone stuff its less expensive and flows ALOT of air so its super efficient... I like my stuff it works very well... you can't go wrong with BYT doing an HP tune on it he does amazing stuf from what I have read.
On the racer, I would have waited for the ZZP EFR turbo upgrade. Use ZZP's gnarly cylinder heads with stage 2 cams and valves and a port job which run the HPFP faster for more fuel pressure. I like the TTR mounts, I use them for the tras as well... Get the ZZP stage 2 trans with the 4.45 final drive gear... not sure why you want to run spacers but that's your call... I run a 245/45r18 tire on an 18x8 wheel no problem so I would say get a wheel with proper backspacing and you will be fine... just recommendations though its your car but the build you have planned seems good |
Originally Posted by RyRidesMotox
(Post 6154067)
On the racer, I would have waited for the ZZP EFR turbo upgrade. Use ZZP's gnarly cylinder heads with stage 2 cams and valves and a port job which run the HPFP faster for more fuel pressure. I like the TTR mounts, I use them for the tras as well... Get the ZZP stage 2 trans with the 4.45 final drive gear... not sure why you want to run spacers but that's your call... I run a 245/45r18 tire on an 18x8 wheel no problem so I would say get a wheel with proper backspacing and you will be fine... just recommendations though its your car but the build you have planned seems good But anyway by biggest doubt is concerning the bore. Don't know if I wanna stay 86mm or go 88mm. I run spacers because the Cobalt lowered looks like a train, so I wanted the rims to be flush with the fenders |
Originally Posted by AyrtonSenna
(Post 6154084)
Thanks for the advice about Treadstone. As far as the cams, I thought ZZP only makes stage 1 for the LNF.
But anyway by biggest doubt is concerning the bore. Don't know if I wanna stay 86mm or go 88mm. I run spacers because the Cobalt lowered looks like a train, so I wanted the rims to be flush with the fenders Definitely drop for the 4.45 gears on the trans though, since its gong to be a track car. I know running spacers are safe and all... but I dunno I just never liked doing it. I was always taught (in school, and in practice) that it puts extra strain on the bearings and it puts increased leverage on the lugs... I know, I know but teaching me something different is like trying a tennis ball through a brick wall. |
(Post 6154418)
My bad... finger slip... ZZPerformance - LNF Ported Head, Cams, Tune Combo #17-02-01466
Definitely drop for the 4.45 gears on the trans though, since its gong to be a track car. I know running spacers are safe and all... but I dunno I just never liked doing it. I was always taught (in school, and in practice) that it puts extra strain on the bearings and it puts increased leverage on the lugs... I know, I know but teaching me something different is like trying a tennis ball through a brick wall. The 4.45 tranny ratio is shorter than stock right? It should also help the turbo kicking in faster? But the main thing is: do you know anything either good or bad about boring the block? That's what I'm really looking into it |
(Post 6154453)
It's ok, I have the longer studs on all 4 wheels, 54mm of the Corvette C6.
(Post 6154476)
I know nothing about boring the block on the LNF you should email ZZP about that. I think the intention behind the 4.45 ratio is that it puts less stress on the trans case, along with the revise grinds on gears 1-5. 4.45 will give you better accel out of the corners and unless your running the nurburgring I really don't see you maxing that car on a track... hell that would be like 170mph even with the 4.45 gears.
- Stage 2 tranny with 4.45 ratio - gridled 2.1 block (so I've dropped the Darton's idea) - Wisecos 88mm - Carrillos - ZZP neutral balance shaft - ATI SFI turbo balancer - head/cam combo - Probably (or maybe for sure) I will need a Meth kit - Also thinking to get stronger axles from driveshaftshop. Don't know if level 2 are enough or I need level 5 My only doubt now is: staying with the stock valves that come with the combo or put the Supertech inconel? And eventually, stock size or .5mm oversized? I know it is a hell of a job as far as price, probably around 10k all together, but at least now I know what to get and I hope to be able to do it by the end of 2012 (if the world doesn't end lol:lol:) |
I'd recommend a ZZP or Ky clutch over any other personally... just my 2 cents.
But I have the Clutchmaster already, it is new. Until it dies, I don't have any intention to spend money on something I already have, and 1 month old.
(Post 6156535)
Thank you for all the advices (and don't worry, this time I won't say that you're a nice guy lol. Actually I have to get my ex wife whacked. Can you do it? For how much? Ahahahahahahahaha). I've spoken to Tim at ZZP today and pretty much I made up my mind.
(Post 6157834)
So you are going to run sleeveless in the motor? I don't really like that idea but if ZZP says its cool I guess go for it. They know more than me. The reason why you put sleeves in is to protect the block in case you eat a ring... if you don't have sleeves and your car eats a ring you will need to bore it out more of get a new block, which would be spendy. That's just my .02 so don't take my word for it over ZZP's, they do know ALOT more than I do about this thing so they are the ones to ask. I would say get the strongest axles you can but in all honestly the transmission in this car is going to be a weak link... and replacing a broken axle is alot easier that a new trans... I would get axles that can take a little less power than the trans before they snap, but again just my opinion. I hate 'building something to fail' but in this case I think the axle snap vs a trans case cracking is a no brainer.
Yes their stage 2 tranny will go in at the same time of the motor build. And the axles will be level 5 driveshaftshop |
(Post 6157837)
I'm going with the stock sleeves because they are telling me that the gridle works the same, and if they don't install the sleeves correctly the block will brake. I don't want it to happen after spending that kind of money. I wonder if I can sleeve it and also gridle it.
Stock axles work just fine. You are making the correct decision on going with the ZZP block.
(Post 6158077)
I'm still on stock axles, but with the turbo upgrade and a fully engine build, I'm sure they won't be recommended, and I will go with the level 5
(Post 6158406)
Are you still running stock Axles?
I have broke one stock axle, but that was after dozens of launches on slicks dumping the clutch at 6500, sometimes 7000rpm. Ryan never broke an LNF axle even with his race clutch, slicks, and wheelie bar. He was hitting 1.5 sixty foots.
Originally Posted by Matt M
(Post 6159412)
Btw, what do you think of the build that I'm planning, considering the turbo kit that I already have? Thanks in advance Matt |
this car is a monster already, prob on of the most powerful lnf's on here! good luck with the build and o want a pull in it once this is all said and done, gunna be amazing! ill pm you my phone died i have to get new one lost everyonesnumber
(Post 6159724)
I will just get them to be safe. I rather do things all together.
Originally Posted by Tcobalt421
(Post 6159734)
(Post 6159758)
I would give you higher odds of having the aftermarket axles fail than having the stock axles fail. Its the same situation that I was talking about with the sleeves. A lot of people want to sleeve their block "just to be safe", but the design and the process involved multiply the chance of failure to a much greater level.
Thank you Christian |
Pretty much at the same point. Did an extensive build and now need to build the bottom end for mine. Already have a need ported head built from zzp sitting here.
Kind of funy just sent matt a email asking questons about my build. Anyways Best of luck on the build, looking for advice myself. |
Originally Posted by ULWiz Cobalt SS/SC
(Post 6159808)
I made up my mind because of their incredible support. My only doubt is regarding the valves, I hope they will answer my question soon about it, and I'm sure they will
