Engine harness
Engine harness
I have a 2010 lnf and am putting it back together after it being tore apart for 4 years and im seeing if anyone can get me pictures of there engine bay and the main engine harness all around the motor to make sure that i have everything connected correctly and routed correctly. i think i have everything in place but want to make sure 100 percent
Thanks
Thanks
Every plug basically only reaches the thing it's supposed to plug into and can only plug into that certain thing. With acceptions of vvt solenoids. Which are color coded with gray and black. Grounds, one behind the alternator, 2 on stud by starter by trans, looks like it is on trans but it's not. 1 on driver's side of head behind fuel pump assembly, under cam cap. Think that's it
