Engine rebuild
Old Apr 24, 2012 | 09:37 AM
ingram57's Avatar
Engine rebuild
Ok wats your guys thoughts on k1 rods and Wisco pistons arp head studs and all new seals bearings and gaskets and zzp stage 1 cams I didn't want to write a lot but it would would be cool for some input or advise
Old Apr 24, 2012 | 09:46 AM
ATLsilverSS's Avatar
won't really gain anything with cams unless you get the fuel lobe cams and run e85 or are on a bigger turbo...that said if you do cams get valve springs/retainers too.
Old Apr 24, 2012 | 09:48 AM
jmfselu's Avatar
go big, or just dont go at all.
Old Apr 24, 2012 | 10:06 AM
ingram57's Avatar
Well I need to at least build my bottom end cause I have a cracked ring land :/
Old Apr 24, 2012 | 10:16 AM
ampzor350's Avatar
Balance crank, Callie's compstar rods (if they make them for the cobalt?) wiesco pistons and of course rings and seals. That should make a pretty good bottom end.
Old Apr 24, 2012 | 10:18 AM
ingram57's Avatar
Yeah I read good things about k1 rods and I was looking into getting a neutral balance crankshaft
Old Apr 24, 2012 | 10:26 AM
ampzor350's Avatar
I wouldn't worry about a netrual balance crank if your not going to be revving the car to high. Just get the one you have balanced and call it a day.
Old Apr 24, 2012 | 10:28 AM
ingram57's Avatar
I figured why it's out I mine as well because I plan on building the head in the future
Old Apr 24, 2012 | 10:29 AM
conerboner's Avatar
aren't the balance shafts and the crank entirely different? maybe I'm just a noob lol
Old Apr 24, 2012 | 10:33 AM
ingram57's Avatar
I'm pretty sure they are im not really familer with the neutral balance shafts
Old Apr 24, 2012 | 10:50 AM
ingram57's Avatar
Old Apr 24, 2012 | 10:52 AM
ampzor350's Avatar
The balance shafts that are in the car now are weighted and spin weights that helps counter act the vibrations of the engine. A netrual balanced shaft is not weighted so they just spin freely doing nothing. You usually get them of your going to be revving the car at high rpms.
Old Apr 24, 2012 | 10:56 AM
ingram57's Avatar
But if I plan on building the top end soon should I just put them in while it's out
Old Apr 24, 2012 | 11:23 AM
ampzor350's Avatar
Are you going to be revving the car to 8k? Typically people put them in because they want to revv the car really really high. If your not going to rev the car high then I would just get your crank balanced at a shop. All a netrual balance shaft is a "dummy". It does nothing but spin in the block and keep the timing right. Its just a perfectly balanced shaft that has no offset weight like the stock one.
Old Apr 24, 2012 | 11:28 AM
09CobaltSS1's Avatar
Built head or not, unless you plan on doing a turbo build as well, installing neutral balance shafts is basically pointless if you can't make power past 7000k with the stock turbo.
Old Apr 24, 2012 | 12:12 PM
ingram57's Avatar
Yeah I'm happy with my power now I just need to build motor due to ring land cracking
Old Apr 24, 2012 | 12:21 PM
Chase0224's Avatar
is it needed to bump your thread after 30 mins? if you dont know the answer to a lot of these things, chances are you should have someone build it for you.
Old Apr 24, 2012 | 12:26 PM
Tennpenn83's Avatar
Agreed.
Old Apr 24, 2012 | 12:27 PM
ingram57's Avatar
Well way to be a dick I built plenty of motors just not a cobalt I was just getting some options and just wanted to see wat people are doing thanks
Old Apr 24, 2012 | 12:32 PM
ampzor350's Avatar
I agree on the bumping thing but you don't have to be a dick about the rest. You have to learn somehow and a forum is the best place to gather Information. So your telling me everything you learned ( granted you know) about engines you were born with the knowledge? Lighten up.
To the op, best thing to do is keep asking questions you have and listen to what people have to say. You don't know if you can or can't do it unless you try. Hands on is the best way to learn
Old Apr 24, 2012 | 01:39 PM
FasterIsBetter's Avatar
If you plan on ever in the future upgrading turbos, I'd get the neutral balance shafts and valve springs atleast. That way you don't drop valves or rattle your engine apart when you do decide to increase the rev limiter for a larger turbo. It $600 extra for both but well worth it when you get tired of the stock turbo choking for its life.
Old Apr 24, 2012 | 01:43 PM
kxrida2000's Avatar
this
Old Apr 24, 2012 | 01:58 PM
JacBlackSS/TC's Avatar
if you need any suggestions you have my number now
Pistons: wiseco, i would do a .020 overbore to clean everything up
Rods: K1, good rods, cost effective
Bearings: Cvette bearings
Gaskets: all new oem gaskets
Crank: micro polished
ARP Headstuds
get your entire block balanced
as far as the head if you want the cams now you can, i didn't do that to my car now, because i still wasn't sure exactly what i wanted to do as far as turbos. But with the cams YOU HAVE TO get springs and retainers. It's just up to you to plan out how soon after you are done with the motor that you are going to upgrade the turbo.
Old Apr 24, 2012 | 02:44 PM
ampzor350's Avatar
^ when you say get your entire block balanced I hope your just talking about the rotating assembly...
Old Apr 24, 2012 | 03:17 PM
ingram57's Avatar
yeah thanks i just wanted to no wat other people were doing
