Engine and transmission mounts
Old Aug 4, 2008 | 07:29 PM
marcusicp's Avatar
Will the solid mounts from the LSJ's fit the LNF cars? I am getting wheel hop shifting into second at the track when I use no lift shift and I think these would help. I am hoping it will help me get my 2.2 60's down as well. If they do fit what brands do people like the best? Thanks!
Old Aug 4, 2008 | 07:31 PM
EXsoccer1921's Avatar
TTR said they're upper motor mount fit. not sure about the trans.
Old Aug 4, 2008 | 07:33 PM
TurboTechRacing's Avatar
Yes they are all the same They fit both tranny and engine.
Old Aug 4, 2008 | 07:41 PM
marcusicp's Avatar
Thanks for the fast replies! So this should help with my wheel hop going into 2nd right?
Old Aug 4, 2008 | 07:43 PM
Dead Zen's Avatar
all trans are f35, no reason they wont fit
Old Aug 10, 2008 | 07:30 PM
HDTuning&Performance's Avatar
Yes, it should help with wheelhop some.
Old Aug 10, 2008 | 08:20 PM
marcusicp's Avatar
It shouldn't void my warranty should it? What could they blame on solid mounts other the a cracked transmission case?
Old Aug 10, 2008 | 08:30 PM
If you have any worries, just swap back the stock mount when you have service, it takes 10 minutes Plus it should help prevent tranny cases from cracking, as it comes from wheel hop sometimes.
Old Aug 10, 2008 | 09:14 PM
marcusicp's Avatar
That quick? For all of them? Sounds too easy to be true!
Also, what other things are available to help with traction and wheel hop?
Old Aug 10, 2008 | 09:40 PM
No the upper mount in 10 minutes. The 2 tranny bushings, I doubt they would even notice
The solid mounts should take care of the wheel hop. Traction is related to tires
Old Aug 10, 2008 | 09:48 PM
SmokinJoe's Avatar
What about the Ingalls Stiffy - are they swappable?
Thx
Old Aug 10, 2008 | 09:58 PM
You wont need an Ingalls and the TTR upper mount. The TTR mount does it all
Also, the Ingalls does not fit on the SS/TC with the factory air box.
Old Aug 10, 2008 | 10:06 PM
SmokinJoe's Avatar
When I flat foot shift, the engine takes a beating. So which mounts do you suggest for someone doing it on the cheap?
Just the front mount (front of the engine, passengr side)?
Old Aug 10, 2008 | 10:13 PM
You will need them all, doing only half is only doing half the job
The bushings are only about $50 for both trans bushings (the kit) so it is not much more to do it right...
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 27, 2015 08:53 PM
