finally bought zfr
finally bought one should be here wednesday ordered friday and looking forward to putting it on this week when i get it and then off to zzp for some tuning!!! :cssNET:
Congrats bro and remember to be gentle with it.
Congrats on the buy! Best mod I've done for my car so far without a doubt!
Originally Posted by Shanedude
(Post 7343516)
Originally Posted by justabalt
(Post 7343531)
yes !! just stay above 3k in 3rd gear but prob wont do nothing stupid til i have a trans waiting for me
Congrats. Expect to have a trans upgrade some time soon! Its inevitable. Haha.
make sure u get the nickel antiseize and put it on every bolt when u install. and have another car ready just in case u need parts. I needed a manifold to turbo stud since I stripped mine cause gm dealer did not antiseize when they had last removed the turbo. Canadian tire where I lived had exactly what I needed thank God. oh yes and if u have bad fuel injector seals that are no their last leg, u will find out once u got turbo on and running at high psi. if u get misfire and a lot of backfire, that's ur issue. that's what happened to me.
im kinda thinking i should of ordered the extended tip on it cause i have injen chargepipe and kinda thinking it wont fit.... anyone have any trouble with that
Originally Posted by SeanEE89
(Post 7343535)
The torque curve for the ZFR is a lot more forgiving then the stock turbo actually. You don't have to be as conservative as a lot of people like to believe.
Better order the extended coupler. It won't fit with the small injen coupler. Even then my injen cp was a complete pita with the zfr. Ended up just getting a zzp upper cp.
Originally Posted by Wert842
(Post 7343601)
could i just install a longer coupler for the time being or just throw the stock one on ... would that make a difference in power with the stock charge pipe?
I guess the stock one would work but you'd have to rig something up to allow for the 3-4" difference of inlet length of the stock turbo to the zfr connecting to the pipe.
Extended tip would be easier to attach coupler, but extended coupler works fine, it's really long so u can cut it to what u need
You should've got the welded extension. Mine was bolt on and go, although i did have to clock the compressor housing a bit once it was in, but ran with stock charge pipes for a week, then got the zzp upper.
Goodluck with it. I am loving mine so far!
Did anyones zzp upper cp lined back up to put the mounting bolt back in? After I installed the zfr it wouldn't line up
May have to trim your coupler? Mine fit back in just fine.
Double check is seated in the lower coupler correctly as well? |
zzp fixed it for me and there sending me the extended tip !! zzp is awesome and has great customer services!!
