finally bought zfr
Old May 18, 2014 | 01:05 PM
justabalt's Avatar
finally bought zfr
finally bought one should be here wednesday ordered friday and looking forward to putting it on this week when i get it and then off to zzp for some tuning!!!
Old May 18, 2014 | 01:36 PM
Shanedude's Avatar
Congrats bro and remember to be gentle with it.
Old May 18, 2014 | 02:09 PM
SeanEE89's Avatar
Congrats on the buy! Best mod I've done for my car so far without a doubt!
Old May 18, 2014 | 02:21 PM
justabalt's Avatar
yes !! just stay above 3k in 3rd gear but prob wont do nothing stupid til i have a trans waiting for me
Old May 18, 2014 | 02:50 PM
SeanEE89's Avatar
The torque curve for the ZFR is a lot more forgiving then the stock turbo actually. You don't have to be as conservative as a lot of people like to believe.
Old May 18, 2014 | 03:52 PM
Wert842's Avatar
Congrats. Expect to have a trans upgrade some time soon! Its inevitable. Haha.
Old May 18, 2014 | 06:13 PM
tomj77's Avatar
make sure u get the nickel antiseize and put it on every bolt when u install. and have another car ready just in case u need parts. I needed a manifold to turbo stud since I stripped mine cause gm dealer did not antiseize when they had last removed the turbo. Canadian tire where I lived had exactly what I needed thank God. oh yes and if u have bad fuel injector seals that are no their last leg, u will find out once u got turbo on and running at high psi. if u get misfire and a lot of backfire, that's ur issue. that's what happened to me.
Old May 18, 2014 | 07:04 PM
justabalt's Avatar
im kinda thinking i should of ordered the extended tip on it cause i have injen chargepipe and kinda thinking it wont fit.... anyone have any trouble with that
Old May 18, 2014 | 07:07 PM
justabalt's Avatar
gotcha.. well im already tuned on zzp and going to install this asap and then head up to zzp any recommendations on drive ability?
Wert842's Avatar
Better order the extended coupler. It won't fit with the small injen coupler. Even then my injen cp was a complete pita with the zfr. Ended up just getting a zzp upper cp.
Old May 18, 2014 | 07:19 PM
justabalt's Avatar
little late for that ill just have to get the zzp upper charge pipe but will the stock one work for now
Old May 18, 2014 | 07:25 PM
justabalt's Avatar
could i just install a longer coupler for the time being or just throw the stock one on ... would that make a difference in power with the stock charge pipe?
Old May 18, 2014 | 07:55 PM
Wert842's Avatar
I guess the stock one would work but you'd have to rig something up to allow for the 3-4" difference of inlet length of the stock turbo to the zfr connecting to the pipe.
Old May 18, 2014 | 08:13 PM
tomj77's Avatar
Extended tip would be easier to attach coupler, but extended coupler works fine, it's really long so u can cut it to what u need
Old May 19, 2014 | 07:18 AM
08VRSS's Avatar
You should've got the welded extension. Mine was bolt on and go, although i did have to clock the compressor housing a bit once it was in, but ran with stock charge pipes for a week, then got the zzp upper.
Old May 19, 2014 | 07:22 AM
DCsnow1000's Avatar
Goodluck with it. I am loving mine so far!
Old May 19, 2014 | 09:38 AM
alerosaint's Avatar
Did anyones zzp upper cp lined back up to put the mounting bolt back in? After I installed the zfr it wouldn't line up
Old May 19, 2014 | 09:40 AM
DCsnow1000's Avatar
May have to trim your coupler? Mine fit back in just fine.
Double check is seated in the lower coupler correctly as well?
Old May 19, 2014 | 11:19 PM
justabalt's Avatar
zzp fixed it for me and there sending me the extended tip !! zzp is awesome and has great customer services!!
06MetallicBalt
Jul 20, 2025 08:47 PM
deviance
Nov 24, 2015 05:51 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Oct 1, 2015 08:17 PM
