Flashing CEL after NLS=Fail?
Old Mar 18, 2009 | 10:36 PM
Iam Broke's Avatar
I was wondering if the flashing CEL after a NLS means I had an epic fail. Had it happen a few times stock & also tuned after a few pops with a NLS. Am I over revving or just too damn slow?
Old Mar 18, 2009 | 10:37 PM
HB_SS/TC's Avatar
Let me guess traction on?
Old Mar 18, 2009 | 10:39 PM
Iam Broke's Avatar
I was in Competitive mode, so some ESC is still active. Also have a LSD on it.
Old Mar 18, 2009 | 10:41 PM
BLAZIN07SS's Avatar
I'm too JDM for you
flashing cel is an indication of severe misfire
Old Mar 18, 2009 | 10:46 PM
RYRO14's Avatar
yeah u misfired. It has happened to me as well no big deal.
Old Mar 18, 2009 | 11:04 PM
Gestapo007's Avatar
^bad news
i thought misfiring was pretty serious. Hear alot of LSJ guys having that problem and next thing they look at their spark plugs and their ***** fucked
Last edited by Gestapo007; Mar 18, 2009 at 11:04 PM. Reason: Automerged Doublepost
Old Mar 18, 2009 | 11:07 PM
umrdyldo's Avatar
quite doing that.
Your momma must have dropped you on your head.
Flashing CEL = fail
You are killing the engine and just laughing about it
Old Mar 18, 2009 | 11:16 PM
Boosted SS's Avatar
This happened to me the other day as well, I laid off the gas for a bit then got on the gas for a bit, tried some NLS's and everything seemed to be fine. Too slow to shift is what I chalk it up to, having it happen too often might start to eff up your engine tho.
Old Mar 18, 2009 | 11:27 PM
blackbolt89's Avatar
i don't even have a t/c and know that flashing cel is bad news!
Old Mar 19, 2009 | 12:28 AM
idlingmike's Avatar
Where do I even start..... So many things can trigger an CEL on an obd2 car. --malfunctioning catalytic converter, egr, incorrect idle, evaporative emissions to name a few. Even not properly tightening your gas cap will trigger an obd2 code. None of the above nor a misfire has even a remote chance of hurting your engine in any way.
-M
Originally Posted by umrdyldo
quite doing that.
Flashing CEL = fail
Old Mar 19, 2009 | 12:37 AM
BLAZIN07SS's Avatar
I'm too JDM for you
-M
a flashing CEL is an indication of a SEVERE MISFIRE.
Old Mar 19, 2009 | 12:47 AM
agent007kimball's Avatar
So I'm confused....the CEL was going off in your car when you were stock....and THEN you decide to do a custom tune?
Please tell me you at least brought this to the dealer for warranty work before you did the tune
Old Mar 19, 2009 | 01:02 AM
idlingmike's Avatar
Misfire, even SEVERE MISFIRE has no chance of causing engine damage of any kind.
Old Mar 19, 2009 | 01:19 AM
IsItFast?'s Avatar
.... wow.
Old Mar 19, 2009 | 01:20 AM
07cobaltguy's Avatar
Originally Posted by IsItFast?
.... wow.
you too? i guess im not the only one scratching my head on that guys posts.
Old Mar 19, 2009 | 01:21 AM
1badBlueberrySC's Avatar
You are too slow! Shift faster...
Old Mar 19, 2009 | 02:00 AM
Gestapo007's Avatar
im thinking anything thats not normal is probobly bad for the car
Old Mar 19, 2009 | 02:07 AM
codytheoutlaw's Avatar
it wont cause much damage in an n/a car. turbo cars are a little different
Old Mar 19, 2009 | 02:11 AM
slowstang's Avatar
I'm willing to bet this misfire only appears when the car hasn't warmed up yet. Let the car get to 180-190 degrees before you NLS. Problem solved. Don't ask me how I know.
Old Mar 19, 2009 | 02:12 AM
misfires on ANY car is a bad thing...
Old Mar 19, 2009 | 02:57 AM
1WhiteSSTC's Avatar
Because nobody else has mentioned it, are u absolutely positive it was a CEL or was it a tranny light flashing?? If it's the tranny light u probably did a NLS while the car was still a little bit too cold, i did this once and that was the result. Coolant temp was up but the car itself hadn't warmed up enough, i might have shifted early too.
Old Mar 19, 2009 | 04:02 AM
Zander916's Avatar
I had it happen to me as well. I know exactly what he's talking about. It's the CEL. Mine kept flashing until I shut the car off AND disconnected the ECU for a while.
I'm POSITIVE it's severe misfire. I concentrated on correcting two things and haven't had it since.
1- Make sure you are quick when you do NLS (I don't think this was my problem)
2- Make absolutely sure you are very near redline when you do it. It's got to be close. If your tune raised the redline to 7K even for just a couple gears. Take it to 7K in those gears before you NLS.
If either of those are not dead on... MISFIRE.
EDIT: I researched on misfires some. It seems to me the biggest threat of damage is to exhaust components such as Catalytic Converter and on a turbo engine likely the turbo. (They get overheated from excess fuel igniting in the exhaust)
Old Mar 19, 2009 | 04:35 AM
EthensCobalt's Avatar
ok fellas its misfire due to nls while car is not yet above 180* you shouldnt really be boosting at all untill the car is at running temp
Old Mar 19, 2009 | 07:46 AM
Iam Broke's Avatar
Thanks for all the feedback. It's a possibility that it might not been completely warmed up when it happened, but I think it was. I've only seen it occur maybe 3 times in 12,000 miles after a NLS so I prob screwed it up shifting too soon, too slow ect. Last time it happened I know it was late at night and I was pretty tired so I figured I caused it.
Old Mar 19, 2009 | 07:56 AM
slowswap's Avatar
What do you think is happening when you NLS? It's a purposely cutting ignation to certain cylinders. Of course it's going to throw a misfire code. If you're getting a misfire code, you're probably taking to long to NLS.
