View Poll Results: Which color spring should we use with Trifeca?
Green
69.57%
Yellow
30.43%
Voters: 23. You may not vote on this poll
Forge BPV Green vs. Blue
Since more and more people are getting these, which one should be used for Trifeca tuned cars?
And I just noticed I put blue in the post title /slap across face
From Forge:
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
The above figures are estimates only and should only be considered as a guideline
Please note - fitting a stronger spring into a valve will not increase boost pressure unless existing pressure is being lost. Failure to allow the valve to operate by installing a spring which is to strong may cause damage to the turbocharger.
Please note - the red coded springs should not be installed in the DVR or DV007 diaphragm valves
Forge Motorsport | Alloy Fabrication
So yellow for gm stage 1. Yellow or blue if you are tuned most likely. But in all reality you have to try it and see what your car likes the best.
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
The tune won't matter.
From North's post:
From North's post:
i hope forge makes a better working design for the balts than our stage 2+ gti. One Ive thrown away and one I threw at the the wall and it is still laying in the corner of my garage. OEM GTI D VALVE FOR LIFE HERE ON OUT, holds strong 21lbs.
what year GTI. The forge BPV for the 2.0tfsi motor was lightyears ahead of the retarded D revision diaphragm that split under 10psi. Then Audi/VW group came out with the piston style F revision, which is the EXACT SAME thing as the forge DV. If you are referencing the 1.8t motor, the Forge DV is the gold standard for VW motorsports.
06 2.0 gti forge fmic, all forge charge pipes, 3inch magnaflow stainless r32 exhaust with r32 bumper, arthur exchange evil ray time attack wheels, hhr springs, apr 2+ with $900 apr fuel pump and the list goes on. You would think a $450 doller valve would outperform the d valve but twice I learned not to try and both forge valves were a so called new design.
the FMFSITVR most places sell for 200$, or 150$ at any vw/audi car show. Again, pretty much the gold standard in VW motorsports. Especially with just bolt on's and a tune, that K03 isnt going to surpass or even tax the forge bpv. Unless you bought it from an idiot that put a super-high spring rate in there, that valve should operate infinitely better than the diaphragm. Really the only thing that ever goes wrong with the FMSITVR is the solenoid, and thats a super rare occurance that forge will typically send you a new one for free.
The forge BPV for the k04, the one were all buying, doesn't use a solenoid, so theres really no point of failure at all. The stock diaphragm can split, but the forge piston operated one can't split. Theres pretty much no point of failure on it. Quality piece at a great price.
450$ valve?! the valve you should use on that motor is this one: Forge Motorsport | Alloy Fabrication
I have the forge spacer aswell, also my valve doesnt look like that, it had the plug harnnes that the oem plug went into aswell as 3 or 4 vac lines. It work golden for few months, then take apart and clean,lube then instal. rinse repeat got old. My apr dealer were I live doesnt carry them no more for people were havn probs and buggn him not forge. Plus ive called forge few times and I wish they said send old will give new lol either way its my girls car now, has lots of pink on it and she loves it and it runs smoothly. Thats all I can ask for now. Wait im suppose to of left oh snap close you eyes gdub
From Forge:
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
you only want to upgrade the spring if the lowest possible spring is insufficient. Try the green, if its leaking boost/not holding boost, then upgrade. Too strong a spring will surge.
Okay, I understand... Just for discussion's sake, since Trifecta tunes are almost always at least 22.5psi, if you use the green, you are guaranteed to be over the 15psi range it lists... How will I know if the green is not working right? Will I not reach 23psi on the boost gauge? Sorry but I am really new to this and do NOT want to screw my turbo up (Or do I??? BNR 2860...) lol. I imagine surge is where the bpv releases and stops consecutively and quickly?
