Forge Motorsport BPV Review.
MY guess is its this one since no one answered your question. This is for an ASTRA VXR or the CORSA VXR which just so happens to use the same K04 turbo that our car uses... They are LNF engine cars.
Can someone answer his question cause I too am interested in this.
I had a forge bpv on my ms3...LOVED the noise. I was wondering why they didnt make one for the lnf....well hahah they do.
The one thing I liked about forge's, is that it came with shim's and multiple springs. I see yours only came with 2 springs? But there is a spring kit that you can order from forge that will come with 4 springs and shims
http://forgemotorsport.com/content.a...roduct=FMDVTUN
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
The above figures are estimates only and should only be considered as a guideline
Please note - fitting a stronger spring into a valve will not increase boost pressure unless existing pressure is being lost. Failure to allow the valve to operate by installing a spring which is to strong may cause damage to the turbocharger.
Please note - the red coded springs should not be installed in the DVR or DV007 diaphragm valves
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Forge Motorsport | Alloy Fabrication
I think the forge has the normal forge sound right gdubs? Kinds like 2 swords clashing...metal ping kinda sound. gawd I loved it...goosed the pedal to get mario a coin!
mine never sticks and all i did was slap it on the car... does its job just fine and it was 19* this morning... the stock BPV was horrible about sticking and causing it to surge at light throttle... i can hear it open and close much more often with my AEM intake than i could the stock BPV... it also seems to have calmed down the cold start surge to an extent...
I think it should be the first mod done to your car... before a downpipe or any other stuff... reliability ftw
