fuel in oil
fuel in oil
Well, it appears i am getting fuel in my oil. oil is black and thinned out. also is overfull and smells slightly of fuel. so, i'm thinking the hpfp is bad, right? any other possibilities? who has hpfp for cheap??
All LNFs have some fuel in the oil...i notice fuel smell too. Send your oil to blackstone to see if that is actually too much fuel. I'd say the HPFP was bad if you were getting horrible gas mileage and it reaked of gas. but a little smell is normal
Yeah, like others have stated, it will be either a HPFP seal that went out, leaking fuel into the head and down into the oil, or a leaky injector that leaks fuel into the cylinder and the fuel makes its way past the piston rings and into the oil pan.
Just wondering but I had my HPFP changed out by the dealership. Is it normal for them to also change out the seal. I really dont know cause I don't know what all's down there.
The only, "seal" that there is that is actually changeable is a gasket that's between the pump and the face of the head. The FSM says to change that when the pump is serviced so I would assume they did. Anything else is likely internal and probably not serviceable.
But after they changed the HPFP my oil still has a fuel smell but not near as bad. So, to the OP, changing it out may solve your issue.
That gasket won't affect fuel leaking into the head or not though. It simply seals up the space between the pump and the head. Therefore, the likelihood of a leaky injector just went up if you're still having the fuel smell after the new HPFP was installed.
On an unrelated yet related note lol, there's a gas tank recall right now for some of our cars that replaces the gas tank seals and fuel pump in the gas tank. I suppose it could be possible that you're smelling that...? Just another thought.
^This
Mine is at the dealer as we speak getting it done. I've been smelling fuel every morning now for months or after the car has sat at work for hours.
Correct, but it wouldt hurt to go to the dealer and explain the fuel smell and that you know of the recall. They may still do it.
i don't smell gas outside of the vehicle. i just said that the oil (smelling the dipstick)
smells a little like gas. also the dipstick is not registering normal. it is over full.
thats why i think i am getting gas in my oil.
Got the old oil? Send a sample to Blackstone Labs, they'll send you a free shipping container. I've got 2 here.
LNF oil always smells of gasoline ( or ethanol). Last test I had done on the LNF at 45k miles showed less than 1/2 of 1% fuel. They say anything under 2% is golden. Oil had 5k on it when sampled.
Maybe my head is just screwing with me (been known to happen often) but I had my pregnant wife sniff it today and she can't smell ANY gas in the oil. I don't about other girls but when she is pregnant she has a nose like a blood hound... Speaking of blood hounds... I ran one over today.
the oil life monitor was down to 4%. just gonna keep a real close eye on the
oil level for right now.
That would be why. Blow by sir. Some combustion and fuel is blown past the rings on any and all engines. I never change my oil at 8,000 miles. 5-6,000 at the most. Its best to change it around 25-35% on the indicator.
