Gas fill up
I'm just wondering if this has happened to anybody else but, has anyone else realized when you put gas in the car it takes a while to start up? and i use 93, and no its not the gas station... any idea's? :cssNET:
never noticed that
mine doesnt do that, but i have noticed when u stop moving u hear the gas sloshing around quite easily
In my ss/sc it did that not in my ss/tc!
Nope. Never happened to me. My car has never given me problems with starting.
Check your EVAP purge solenoid.
my friend has a ss/tc never has had that problem.
yeah
mine has dont that are u tunned? if so what tune? i am tunned with hptunners and i have this issue some times kinda starts like an evo on ems lol
I have no issues with starting the car ever. always turns over and starts up immediately.
I have that same problem!! its annoying as hell! where is the evap solenoid??
Originally Posted by KillerBee
(Post 4244542)
x2
check the evap purge solonoid --- roughly 30 dollars part, and 2 minute fix |
It will also do that if you let it run nearly out then fill up to brimming, or if you brim it up each time. Stop filling when the filler clicks off the first time.
Never had this issue, sorry.
I use Chevron 92 and never have had that problem
Originally Posted by boostaddict36
(Post 4245116)
Originally Posted by Steven Flit
(Post 4465713)
x2
Originally Posted by IsItFast?
(Post 4466082)
Originally Posted by Hotshot768
(Post 4466512)
Where is it located??
dealer I'm not sure but, Crate engine depot may have it? I dont think so tho |
it happened to me i jus got it fixed from the dealer. it is the evap surdge solenoid its covered under warrenty.
I had the solenoid replaced, but all that did was throw a light at me. Never had any problems starting up. Stock or tuned. I have however got the ignition stuck trying to crank once or twice. Know hw we can just barelly turn the key and it does the rest? Well, I did that and it just sat there cranking. Hasn't done it in a long time though.
Originally Posted by slowbalt84
(Post 4466609)
^ this guy hit the nail on the head. I have done this twice. You ran "almost" out of gas. If the DIC says you have 30-40 miles left that means you are pretty much out. Trust me i have ran out of gas plenty of times in our work truck and i know what it feels like. One time i was filling up the balt when it said i still had 34 miles left and the damn thing took like 5 minutes to start. Then i took off out of the gas station and it fell straight on it's face and was very sluggish. Guarantee this is what happened to you. been there done that
(Post 4466737)
gmppdirect
Anyone have a part number for this? I'm not able to find it for the life of me. And I'm experiencing it now too, everytime I open the gas tank to fill up it never fails now.
You know its interesting... had this problem once before, right after I as running on fumes (long story, forgot my gas key, then my wallet, interceptor read 0.0 gals available for about 15miles.. anywho)
After reading through this thread, Ive now had that code set 2x times, but ONLY right after a hard 2nd gear pull with the trifecta tune ON. Doesn't throw the code with the tune off. I'm going to do more experimenting, but to the others getting this code, is it during startup or with an aftermarket tune right after a hard run? Turn on right after you let off. |
Originally Posted by turbossdude
(Post 4466980)
Mine threw a code long before any "problem" was apparent Then, while waiting on the dealer to order the part...after filling up, the darn thing wouldn't fire. It just kept cranking, and cranking, and cranking. After it eventually (sort of) caught, it was idling at only ~250rpm and DIC gave the dreaded "reduced engine power" warning. Can't wait for this thing's warranty to expire....... |
