Gas fill up
Gas fill up
I'm just wondering if this has happened to anybody else but, has anyone else realized when you put gas in the car it takes a while to start up? and i use 93, and no its not the gas station... any idea's?
^ this guy hit the nail on the head. I have done this twice. You ran "almost" out of gas. If the DIC says you have 30-40 miles left that means you are pretty much out. Trust me i have ran out of gas plenty of times in our work truck and i know what it feels like. One time i was filling up the balt when it said i still had 34 miles left and the damn thing took like 5 minutes to start. Then i took off out of the gas station and it fell straight on it's face and was very sluggish. Guarantee this is what happened to you. been there done that
I had the solenoid replaced, but all that did was throw a light at me. Never had any problems starting up. Stock or tuned. I have however got the ignition stuck trying to crank once or twice. Know hw we can just barelly turn the key and it does the rest? Well, I did that and it just sat there cranking. Hasn't done it in a long time though.
ok thaks. Where would it be located on the car?? how could I tell something has changed with it?
Last edited by Hotshot768; Nov 24, 2009 at 02:27 AM. Reason: Automerged Doublepost
You know its interesting... had this problem once before, right after I as running on fumes (long story, forgot my gas key, then my wallet, interceptor read 0.0 gals available for about 15miles.. anywho)
After reading through this thread, Ive now had that code set 2x times, but ONLY right after a hard 2nd gear pull with the trifecta tune ON. Doesn't throw the code with the tune off. I'm going to do more experimenting, but to the others getting this code, is it during startup or with an aftermarket tune right after a hard run? Turn on right after you let off.
Mine threw a code long before any "problem" was apparent Then, while waiting on the dealer to order the part...after filling up, the darn thing wouldn't fire. It just kept cranking, and cranking, and cranking. After it eventually (sort of) caught, it was idling at only ~250rpm and DIC gave the dreaded "reduced engine power" warning.
Can't wait for this thing's warranty to expire.......
