Gauges and how to?
Gauges and how to?
I just traded my SS/SC for a TC and I was wanting to know if my Aerforce Interceptor gauge and my Mechanical Boost gauge will work on the new TC?
Im guessing no i just bought mine and had to get the CAN data line one well because the communications between the modules are high-speed now. But i could be wrong
of course ur boost gauge will work, just find a place to hook up ur line by the turbo or manifold or somewhere inbetween there.
I knew the Boost would work I just dont know exactly where the vaccum line is. I have only spent a max of 10 min the hood so far though. Its just I hooked the interceptor up and it turns on doesnt show any numbers just names. then shuts off after 45 sec. If it doesnt work then its for sale
Again, a SC Interceptor gauge will NOT work on a TC, only 2.2 & 2.4 gauges will bc they are the CN series version.
Have a look.
http://www.aeroforcetech.com/files/A...ide_basic3.pdf
Have a look.
question about the gauge.
How does one read o2 voltage. as in how do I go from afr to voltage?
and it looks like all you need to do is sell yours and buy the cn version because according to their website it should work. I want to get some but will probably wait till summer.
The only reason you would need to read volts is if you had an aftermarket wideband. These will have a box that interprets the o2 sensor and do some processing. It will then output a 0-5v analog signal that corresponds to an afr.
Any idea of an exact location of this hose since I have about 10 min under the hood time so far.
Have a look.
Have a look.
