Gm lnf stage 1 kit troubles??
Old May 16, 2010 | 02:37 PM
sport-o!'s Avatar
hey 'balters...
since the release of the lnf stage kit, has anyone come across any problems? meaning, fitment issues (sensor hardware), CEL issues, driveability issues, etc....i really want to get this, but i have heard here and there some people were disappointed. i tried a search a few times and didn't find anthing. if there is a thread somewhere, please direct me there please!!
thanks...
Old May 16, 2010 | 07:11 PM
ADIDASS's Avatar
I had the dealership install mine. I haven't had any real problems. I get a bit less fuel mileage, and I boost much easier now. I have a hard time keeping it in the vac when accelerating. Other than that, I haven't had any problems.
Old May 16, 2010 | 07:15 PM
gdubs's Avatar
0 issues. BUY NOW
Old May 16, 2010 | 07:28 PM
D-mac's Avatar
If you have access to someone with HPT you can save a ton of Money by buying Performance Autowerks stage sensors and having your PCM flashed by someone
If you are worried about Warranty you could buy the sensors from Crate Engine Depot and get it flashed at the dealer
Old May 16, 2010 | 08:36 PM
sport-o!'s Avatar
Originally Posted by gdubs
0 issues. BUY NOW
thanks!! you sound like a late night sales add!!! "buy now"...if only it was $19.95 like everything else they sell on late night!!!
thanks d-mac...this is something to consider!!!
Old May 16, 2010 | 08:57 PM
TommyP's Avatar
AWD > FWD
I've had no problems whatsoever, but I've only had it for a week. I've heard of a few people popping off stock charge piping from the extra boost but that's only because of the poor clamps and it's happened totally stock.
Old May 16, 2010 | 08:59 PM
CrateEngineDepot's Avatar
Give us a call, we can hook you up.
Old May 16, 2010 | 09:08 PM
sptrdss's Avatar
I have had mine on for about two months and no problems whatsoever.I have the k & n drop in and just installed the Hahn S.S. CATTED D/Pipe which made a big difference.Haven't had any issues at all.
Old May 16, 2010 | 11:31 PM
T-Man's Avatar
install your own **** and then have the dealer flash if that's the route you choose to take
Old May 16, 2010 | 11:41 PM
BK05SS's Avatar
no issues, buy parts from Crate Engine Depot, 500$ shipped, go to dealership and get it installed. 190$ install cost.
Had it on for over 1k miles, no issues. DO NOT install yourself UNLESS you're an expert at kripping wires, soddering them together and aren't worried about screwing up the wiring (I believe replacement part if you screw up is 130$) I'm by no means an expert mechanic or an engineer, but in my basic understanding this is what can happen.
Great buy and keeps full warranty intact
Old May 17, 2010 | 01:38 AM
zeustang's Avatar
Originally Posted by sport-o!
hey 'balters...
thanks...
No, no, and no. 3k miles in and I've had relations with my car at least 42 times. Make sure the GM tech isn't a 'tard and properly crimps (kripping?) and insulates the wires. You don't want the harness for the lower TMAP rubbing on the AC line.
I had a high RPM missfire for a while and though it was plugs. I put the NGK 3787's in (one step colder) thinking that was the issue. Turns out the simpleton GM tech left the lower TMAP bolt loose causing a boost leak. Idiot. I tightened it down and have had no issues since then.
Old May 17, 2010 | 09:21 AM
jphugel11's Avatar
had mine for 5k now, no issues at all except a weird thing causing my bpv to get stuck open, but I'm not really sure if that has anything to do with the GMS1, after you get it buy yourself a catless downpipe.
Old May 17, 2010 | 09:27 AM
JPizzle's Avatar
Get it! It's great!
Old May 17, 2010 | 09:47 AM
rnjmur's Avatar
I have had it on since I bought the car and have had 0 issues.
Old May 17, 2010 | 03:16 PM
jpower102's Avatar
Got mine in september, drove it all winter and no problems .. although the temptation of going fast makes the police stopping you a bigger issue ;p
I have also killed a few cars .. I'm so bad
Old May 17, 2010 | 03:44 PM
Terminator2's Avatar
CED has the replacement 3 bar sensors for $16. Here http://www.crateenginedepot.com/stor...P2533C221.aspx
Connectors can be found here. They are not preassembled though so you have to wire them and put them together. http://www.bmotorsports.com/shop/pro...oducts_id/1625
So for ~$80 total you can have a working stage kit you just need to have or know someone with HP Tuners who can write the stage 1 OS into your car.
northvibe's Avatar
No fitment issues on stock hardware. The place people have issues is aftermarket IC's and the bottom sensor rubbing on the AC line. OR if it is installed wrong you will get a CEL and that can be fixed.
No worries, I've ran mine for a few months now and love it, just got a downpipe too
Old May 17, 2010 | 08:29 PM
rnjmur's Avatar
I don't know how much your car appreciates you having relations with it.
Old May 17, 2010 | 08:52 PM
sport-o!'s Avatar
^^ i was thinking the same thing!!
thanks guys...this all helps a lot!! so far it runs great...i want to keep it that way!! the ss goes on many a trip up nort'!! getting there a weeee bit faster would be nice!
Old May 17, 2010 | 08:59 PM
CrystalRedSS's Avatar
0 issues. BUY NOW
^^ What he said lol.
Old May 18, 2010 | 03:52 AM
SSlobalt's Avatar
Just wanted to put all these GMS1 posts at the top to see the ridiculousness.
Old Sep 29, 2010 | 12:51 PM
One-Bullet-Banta's Avatar
what wires were crimpt, where are they located i have had mutliple problems with my GMS1 kit and dealership is no help
Old Sep 29, 2010 | 06:51 PM
vahdyx's Avatar
Originally Posted by Terminator2
CED has the replacement 3 bar sensors for $16. Here 3 Bar MAP Sensor 55206797 - Crate Engine Depot
Connectors can be found here. They are not preassembled though so you have to wire them and put them together. Home » Shop » Connectors / Harnesses » Bosch » 4-way sealed Plug Bosch BSK Connector Kit for Bosch MAP Sensor
Now is this just GMS1 parameters or actually a GMS1 tune that can pass at the dealership
Old Sep 29, 2010 | 10:01 PM
sanchez's Avatar
just got my car back from the dealership today to try and fix a problem i am having i got an 09 ss tc with the gms1 on it when i first got the kit i would boost 17-18 pounds and today i brought it into the dealership cause my boost has dropped down to 12 pounds i also have the k&n intake on my car so anyways the dealership told me i threw a code on my maf sensor and that they cleaned it and that everything is fine so i took my car out for a drive and im still only boosting 12 pounds nothing more they also told me i have no boost leaks so now i dont know where to start cause when the gms1 was first installed it was a huge gain boost shot up no problem and seems that over the last few months its slowly been going down i have however also noticed that when im driving around and off the throttle the vacumm is way down like 60 70 when that used to be about 20 on the gauge so im not sure if that has something to do with it or not any help would be great
Old Sep 30, 2010 | 12:07 PM
rnjmur's Avatar
It is possible that the guage is the problem and the car itself is fine.
