GMPP LSJ Clutch Upgrade For LNF
No need to measure, I use micrometers often. I understand One hundredth of a inch isn't much. Also u don't need to defend your point to me, tell it to CED. They are the ones standing behind that info.
And I would think this method would cause more problems with TOB compared to just resurfacing the clutch disc mating surface of the flywheel. This would move the entire pressure plate further away from TOB, making over extention possible unless you shim the flywheel outwards toward the input shaft. My .02
It's totally moot. You hardly remove anything.
This is where I'm not following. If you move the mating surface away from the TOB, if anything you're moving the springs towards the TOB. Pushing in on the springs moves the clutch outwards or towards the TOB. I don't see how you could shim anything.
Yes the info CED provides for the LSJ clutch upgrade has a whole 2-3 pages of info about TOB over extention.
See how when you push the clutch pedal down in the car the TOB pushed out to engage the fingers of the pressure plate? This releases the clutch disc from the flywheel.
If you remove material from the flywheel it moves the pressure plate that much further from the TOB since the TOB is bolted to the transmission and the pressure plate is bolted to the flywheel. BUT the material you remove in resurfacing that it will not make a difference in operation UNLESS the shop takes off too much material.
#39
Still, I will ALWAYS recommend a new flywheel to someone looking to replace the clutch as you don't know if the flywheel will be serviced correctly when resurfaced. And if it ends up being resurfaced incorrectly, then you will have to tear the car apart alllll over agian. Even worse would be if you were paying to have it done, then you may have to pay to have the clutch done AGAIN.
So, I revert back to my second post in this thread. It's not worth the risk.
If you know exactly how much material needs to be removed and you are confident it will get resurfaced correctly, that's completely different but I bet 90% of the member here don't have a clue.
#42
Im betting the biggest difference between the stock LSJ clutch vs upgraded LSJ is the pressure plate...wSelf adjusting(LSJ) vs standard(LSJ upgrade - exactly like the lnf). The clutch disc material between the OEM LNF and LSJ upgrade clutch appears to be nearly the same. Anybody have any specific material specs on the lnf vs LSJ upgrade clutches?
#44
The disc is different and it seems to hold a lot better than the stock LNF disc. Friction material must be different. Tuned a few cars close to 450wrtq with it and zero slip even in 4th.
#50
This is a fun thread....it's different...it's the same...you shouldn't resurface....it's fine if you do it right...why take the risk...why waste the money...ah, the great fun of having no data.
Even the pictures of the clutches are inconclusive (other than LSJ being clearly different). The springs on the GMPP are a different color, but of course that doesn't prove anything and the two (LNF and GMPP) disks are reversed so you can't compare the structure. The pressure plates look similar, and who knows if the different color is just due to different photographers/lighting.
CED is a great supporter of this site, but even their comments are confusing. Are we to believe that having different disks is not important? The entire aftermarket world spends a lot of money trying to convince us their disk is magical and will out perform all others. In fact it's basically the only thing that is tune-able in clutch design other than the load generated by the pressure plate. It is what will largely impact coefficient of friction given the pressure plate and flywheel are steel (ignoring exotic carbon clutches). The coefficient of friction is sort of critical....just a tiny (read: really big) bit important.
and, end rant....
Daniel
and, end rant....
Daniel
Matt10tc (04-14-2016)
