Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   GMS1 help (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/gms1-help-262877/)
Supabalt Oct 7, 2011 11:23 PM
GMS1 help
Im about to order my GMS1 kit from CED and theres 2 different GMS2's for the SS/TC. Ones 495 and the other is 485. Which one should i order, i need and answer asap cz im buying it now
Wangspeed Oct 7, 2011 11:27 PM
No, there is only 1 kit for the LNF. It comes with pigtail harness connectors so that you don't have to cut into the harness anymore. Should say LNF or turbo on it.
Supabalt Oct 7, 2011 11:31 PM
My bad i put 2 not 1. If you go on the site tho theres two kits of gms1 that are diff prices...
19212670 Cobalt, Solstice, HHR Stage Kit 19212670 - Crate Engine Depot
Cobalt, Solstice, HHR Stage Kit 19212670HK - Crate Engine Depot
Which one is it?
1badls1 Oct 7, 2011 11:40 PM
Looks like the one for $495 uses a plug and play harness instead of pigtail connectors. In my opinion I would go with the plug and play, it's worth the extra $10 to save you some time. Hope this helps
casionerd Oct 8, 2011 01:09 PM
Get the PNP one. Definitely. No soldering or crimping. Less things to go wrong. Also the install time at the dealership will be faster so there will be a bit less labor charge.
