Gms1 redline????
Old Mar 9, 2010 | 12:56 PM
cresintern's Avatar
Gms1 redline????
with the gms1 does the redline increase???
also, does anyone consider the NLS to be something that is somewhat difficult to do properly. I try it with my gms1 and i still feel a bit of lag in between the shifts, guess i'm dropping off in between...
Terminator2's Avatar
Yes. It is set to 6500 RPMs.
Old Mar 9, 2010 | 12:57 PM
cresintern's Avatar
what was it..
what was it before??
does the rev limiter hit at that number (6500)??
Old Mar 9, 2010 | 01:49 PM
BYT*SS*TURBO's Avatar
6300 stock
About the NLS - are you holding your right foot flat to the floor? The first couple times I lifted a lil bit and it didn't work as well. Also, try doing NLS a lil before redline, it doesnt like when you NLS as you bang off the limiter. And doing it from 1st to 2nd gear, try shifting at ~5800.
Old Mar 9, 2010 | 02:31 PM
6300 stock. The fuel cut delta is 50 rpms so once you get 50 rpms above 6300 or 6500 in the stage 1 tune case it cuts out.
maliki778
Oct 1, 2015 07:39 PM
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
no_ss
Sep 18, 2015 11:03 AM
