Going catless without tune.
So I may be obtaining a Hahn 3' Catless down pipe for my LNF. I don't plan on doing a custom tune for a while. I realize that this may throw a code, but could running catless without specifically tuning for it cause any damage to the engine? I'm on a Trifecta tune currently if that matters.
Also, since the state of Missouri requires a catalytic converter, the guy I'm buying the DP from says that doing a second muffler as a "test pipe" will allow it to pass inspection. Does anybody know exactly how this works? Thanks!
Should still help it spool a bit faster than stock, but you really won't see any real benefits, just make sure you have an inspection done if it's going to run out before you plan on getting the tune.
z28addiction
Sep 28, 2015 12:03 AM
