Going with SynapseTurbo Kit...
yeah i got the kit i running the tune they sent me and it only put done what is in my sig on the dyno. i know with new sensors i can put more done.and right now my car is in the shop getting the trany looked at to see what i can do to t to make it stronger and having a lighter flywheel and spec stage 3 put on. that is what they said i should put on now. and this is my close friends shop.
How long did it take you to install?
Did you have to pull the engine or could you do it from under?
it took me and my friends 12 hours to put it in. but most of the time we where just bsing around it should take you 8 hours or less to put it in. but i would have a shop put it in. safer and you wouldnt have to stress over it. and you can put it on without taking the engine out it just a pain and tight fit to put it in
345whp thats a load of poor tuning or some dumb **** for the synapse stage 3 kit. especially since synapse dyno'd their car at 371 whp and 383 wft-tq with stock exhaust! im also getting this kit by the fall and im aiming for 400whp with extensive tuning and with all my other mods and meth.
I might opt for a bigger turbo
i would wait for the gm kit so you can read more boost. that one think i should of done. but i will be making more when i get my car back i have two little things to put on. but till hp unlocks more stuff we are still limited. but if they got that much power out of the car woth the same tune they sent me the what is different?
I'm sure they will get past the fuel problems soon. If so, I plan to have it tuned all out, put my meth kit back on and spray the intercooler with Nitrous.
Speaking of all this stuff...
To come soon...
Synapse turbo kit (possibly up it to a gt3076r)
Custom 3" exhaust
tranny mounts
motor mount
meth
Nitrous (intercooler spray, though might split it and spray a 50 - 75 shot in the cold side piping)
Full internals
ported intake
ported head
Cutout in DP before cat
spec plus stg 3 clutch
flywheel
CA air suspension
Drag radials
and more exterior mods.....
Might do a partial roll cage because I want to get into Autocross
that should bo it for a while....
then once they get past the fuel issues I wont stop till I reach as close to 450fwhp as possible
Last edited by JsavageSS/TC; Jun 26, 2009 at 06:13 AM. Reason: Automerged Doublepost
Nope
nittos suck for high hp applications..... BFG drag radials are the best>>>There's a reason they've earned the name axle snappers!!!!! GRIP!!!!
Last edited by SportredSS; Jun 26, 2009 at 06:15 AM. Reason: Automerged Doublepost
The tune we send with the kit is a bit more conservative than what we run on our car, as we expect each car to be maximized safety on a dyno and monetarying engine knock. I can tell you we run about 3 deg more ignition timing than is sent on our bas cal. It would be foolish of us to send anything agressive when we are in ny and its 60 deg out vs someone in az @ 120 deg. When the car is maximized it will gain a significant amount of power.
turbo tech racing has the spec plus 3 its 750ish youd have to search for the exzedy thou
here the link for the spec
http://www.turbotechracing.com/produ...dcategory=5615
here the link for the flywheel which you would have to run with the clutch as well
yeah ill take custom tunning k
4gs... plus with that kit you can take way further....
For the tune.... They send you a programmer with the tune file on it?
To come soon...
Custom 3" exhaust
tranny mounts
motor mount
meth
Full internals
ported intake
ported head
flywheel
CA air suspension
Drag radials
To come soon...
Custom 3" exhaust
tranny mounts
motor mount
meth
Full internals
ported intake
ported head
flywheel
CA air suspension
Drag radials
they sent me the file. by the way i have hp so i was able to put it on right after install so i wouldnt throw to many codes.
well they looking at just stronger stuff that it but it like 5000 dollars for the work that like more then a new tranny. so if you want a very good tranny for racing then go a head. i just having then price it for me and they looking at the tranny to make sure everything is good.
To come soon...
Custom 3" exhaust
tranny mounts
motor mount
meth
Full internals
ported intake
ported head
flywheel
CA air suspension
Drag radials
To come soon...
Custom 3" exhaust
tranny mounts
motor mount
meth
Full internals
ported intake
ported head
flywheel
CA air suspension
Drag radials
why wait for the stage kit if someone has figured out how to work around the fuel issue..
Nittos are great tires.. but to make them stick and work on the track - they need to get heated (130- 140 deg).. a 30 second burn out doesnt work, you need to burn them for atleast a full min.. to get them to stick properly.. trust me..
someone in SoCal got 535 WHP (110 oct) - with a piggyback fuel/ign setup and using both the stock DI and a second DI.. all using forged internals, 3'' pipes all around and a GT35.. and using stage 4 puck..
my best friend (39) MSSgt SF BO Sniper - lost his tool - not even married and no kids - and he got $320k pay in the hole on his 7 tour (2 ikill & 5 ahole), the man is crazy - he re-up for ahole - after med clears him.. he even got a pic with bush bedside when he was there..
dont know what they are, i was told about his dyno pulls thats all..
i dont know the name of the guy or the shop to where this was done..
if anyone in Cali / LA or SF reading this - please look out or ask around..
to verify this - Black/Silver 2009 SS 2DR with major motor work done in the last 5 months..
Last edited by redstarpa69; Jun 27, 2009 at 02:50 AM. Reason: Automerged Doublepost
