got my hands on a ss/t car finally.
Old Sep 28, 2008 | 04:52 PM
EatonTVS07's Avatar
i'll need to get lotto ticket first . you need to take it to the track
Old Sep 28, 2008 | 05:14 PM
ColeJJones's Avatar
Bannned
Originally Posted by ColeJJones
i have a question. hopefully someone can answer this one. anyone know which engine is stronger boosted with turbo? lnf or lsj? we have seen the lsj hold 440hp stock. what about the lnf with the same size turbo? anyone know about this?
Old Sep 28, 2008 | 05:20 PM
ColeJJones's Avatar
Bannned
oh **** son. which engine is stronger internally though?? im sure someone knows
Old Sep 28, 2008 | 05:29 PM
Rangerondubz's Avatar
Should be the same minus the head. Cast pistons, forged rods, crank.
Old Sep 28, 2008 | 05:40 PM
ColeJJones's Avatar
Bannned
all aluminum though
Old Sep 28, 2008 | 05:45 PM
R&C_rallySS's Avatar
The SS/TC will be far stronger internals compared to the LSJ. I mean come on, common sense says so with forged parts...
Old Sep 28, 2008 | 05:48 PM
EatonTVS07's Avatar
the lsj has forged parts
Old Sep 28, 2008 | 05:49 PM
ColeJJones's Avatar
Bannned
not the pistons. but i thought the lnf was the same way...
Old Sep 28, 2008 | 05:54 PM
EatonTVS07's Avatar
i know i was thinking the lnf and lsj were virtually the same with minor differences, i dunno though
Old Sep 28, 2008 | 05:56 PM
Bad05SS's Avatar
i want to throw my 05 ss/sc on the dyno and see what numbers i make
its pretty much stock with an airbox mod but for some reason its faster then an 07 ss/sc and has a 1/2 car in a ss/tc
stock vs stock
Old Sep 28, 2008 | 05:58 PM
  #36
PimpLay2's Avatar
nice numbers i wonder what mine throws down
  #37
Z Speed's Avatar
tuned with HPT?
Old Sep 28, 2008 | 06:00 PM
  #38
EatonTVS07's Avatar
Originally Posted by Area47
yepo. all hptuners
yup all hptuners
Old Sep 28, 2008 | 06:04 PM
  #39
blackbird's Avatar
Nice numbers. Any chance you have a chart with SAE correction applied? Depending on atmospheric conditions standard can produce higher or lower numbers and SAE (usually a touch higher) and SAE makes it easier to compare to other cars on similar dynos across the country. Either way, I'm not half as interested in the peak numbers as I am in the overall curve. That looks really nice with no giant spikes and solid gains across the entire powerband.
Both engines use cast aluminum pistons, both of which (along with the rods) are made by Mahle.
Old Sep 28, 2008 | 06:07 PM
  #40
EatonTVS07's Avatar
so basically the power it can hold is basically the same as the lsj?
Old Sep 28, 2008 | 06:10 PM
  #41
ColeJJones's Avatar
Bannned
different engine. you cant tell
but im sure some redline or gxp dude should know
Last edited by ColeJJones; Sep 28, 2008 at 06:10 PM. Reason: Automerged Doublepost
Old Sep 28, 2008 | 06:13 PM
  #42
EatonTVS07's Avatar
i know its a dif engine, but blackbird said they both had cast alluminum pistons
Old Sep 28, 2008 | 06:15 PM
  #43
ColeJJones's Avatar
Bannned
has nothing to do with it holding the same amount of power. head might flow more, rev limits, etc
Old Sep 28, 2008 | 06:25 PM
  #44
blackbird's Avatar
It might be able to hold as well or better but there are some significant differences between the two engines. For example the pistons are both cast aluminum but the design on the LNF is completely different due to the direct injection nozzle placement. The LNF also runs a slightly lower compression ratio. The fueling system is also completely different and the direct injection setup with the resultant different flame front in the combustion chamber may prove to have significant differences in how the LNF will make power and what it can support. The LNF also uses the newer and stronger/reinforced Gen II block but still uses cast iron cylinder liners.
Both engines should have similar max power levels they will support but both will probably require upgrades if you really want to push them far and maintain the best reliability. When trying to make direct comparisons between the two you'd also need to consider things like possible uneven fuel/air distribution and high charge temps due to the blower on the LSJ contributing to internal failure when pushed too far, which should no longer be the case with the LNF and the new intake manifold and fuel setup.
There's lots and lots of variables. By the spec sheets they do look similar but a lot of factors may come into play in the power levels the internals themselves will be able to support.
Old Sep 28, 2008 | 06:27 PM
  #45
06blackg85ss's Avatar
eh it will pretty much be the same power wise, just probably a little better top end with the VVT probably hold a little more boost on pump gas with the 9.2:1 compression vs the 9.5:1 compression. mostly has to do with the tune and how big of a tard the driver is.
Old Sep 28, 2008 | 06:28 PM
  #46
ColeJJones's Avatar
Bannned
were not talking about the blower.
Old Sep 28, 2008 | 06:37 PM
  #47
just throw a big turbo on it and lets see.....
Old Sep 28, 2008 | 06:54 PM
  #48
Z Speed's Avatar
Originally Posted by Cobalttc05
yup all hptuners
ahh missed that...
thought hpt wasnt technically released for the ss/tc yet?
Old Sep 28, 2008 | 06:57 PM
  #49
EatonTVS07's Avatar
i think its been out for awhile i know psycostevo has been tuning them for some time
Old Sep 28, 2008 | 07:34 PM
  #50
foff667's Avatar
Originally Posted by Z Speed
ahh missed that...
Yeah its out & supported in the newest public release, we should have the 09's in beta in a few days as well.
